1986 Buick Grand National
rollie
TurboBuick.Com Supporter!
25,000 If you have any questions please call me, I have every stock part that came of this car engine,trans,wheels etc. Rolland 989-274-9854
60,000 miles B title Arkansas all documentation window sticker service record. Absolute mint condition. No rust ever. New paint due to fading. Stripped to bare metal. Sealed, printed, base coat, clear coat. Chip guard on car.
Engine
600 HP Aluminum head V6. 600 miles on it since Build up. All work professionally done.
Roller Cam Comp Cams
Roller Lifters Comp Cams
Roller Rockers Scorpion
Diamond Pistons 020
Crank Cryoed, shot peened, hardened. Block 509 cryoed, bored and honed W/tork plate Billit main caps. Line bored and honed, water and oil mods. New cam bearrings, and soft plugs. Rods-polish beams, cryoed, shot peened. ARP bolts roll master billit timing set. Clevite rod-main and cam bearings
Champion Alum Head ( Fully Ported ) W/stainless valves.
Total seal rings
Roller Springs.
71 MM Body Front Cover
55 IInjectors
Computer W/3 Chip 17 IB 22IB 26 IB Boost
Balanced-Blueprinted ENG. App 600 Mi all Pro built
BG Customs Stock Mount Intercooler
T63 Turbo
Delphi plug wires
Alum Radiator and 2 Elec Fans
Alum Billit Water Oil Coder
Alum Rear End Cover W/Axle tube Braces
Cat Back Exhaust System
Large mouth Turbo bell
Alum Billit Upper and Lower Adjustable Trailing Arms
Adjustable Boost Actuator
Hot Wire Kit
New 1000 amp Battery
Custom 750 AMP Alternator
373 Posi
Koni ADJ Shocks
Air Bags
ART Carr Converter
Prostar Wheel Front and Rear
Tires ET Street
All Stock Parts OEM ENG. ( Trans Rebuilt ) 60,000 RAD Intercoder, rear end radio, sway bars, fan T arms, Every last nut and bolt Turbo
Transmission By CK Performance Queens NY
Pis-Diamond .020
Billit Main Caps
GNI Heads Alum Full Port
BGC Intake
Roller Rockers
Cam Button
3” Down Pipe 3” Up Pipe
Cold Air Package
Adj fuel reg
Press gauge fuel
Press gauge oil
Press gauge boost
Injectors 55 Pound
Chip 17 LB-22 LB-26 LB BGC Computer
Water Alki Inj BGC
Cross Over Pipe
Welded Manifolds Ported
V Cover Breathers On Alum Buick Covers
Value Covers Buick Alum
Front Cover BGC
Head Studs ARP-Main Studs ARP
Roller Cam Ccam
Solid Roller Lif. C. Cam
70 MM T. Body BGC
Deep pan and pickup- BGC
Oil Pump Kit BGC
Walborl fuel pump ( GSS307 )
Polisher Shot Peened Rods ( Good ARP Bolts ) Cryoed
Hardend-Shotpeend-Cryoed-Crank
There are no track times I have never been to the track with the car.
I live in Caro Michigan I can bring the car to the woodward dream cruise if you would like to see it in person
I didnt put the vin number so ebay closed the bidding I will re list the car tomorrow.
Any dyno numbers? Who tuned it? 373 gears? You made 600 to the wheels with a 63 mm? Race gas? At what boost? No alky kit?
This car is my friends I will do my best to answer all your questions but it is best to call rolland direct.
bowling green customs did the tuning 3 chips
373 gear
he did use race gas with the 27 pounds of boost chip
it does have a alky kit
the car is sold I have all the stock parts for sale if anybody is interested please give me a call or email me.
Greg Blevins
248-672-0307
turbogreg@hotmail.com
Parts do not include shipping.
60.xxx miles
complete stock engine 1800
transmission completely rebuilt with converter 500
stock computer 75
stock posi and gears
4 grand national rims and caps 450
4 weld pro stars with et streets 450
stock radio 100
stock intercooler 150
