were to begain !!!!
to start
ENGINE.....
Heads 1.77 1.50 ss. ferrea valves
ported and polished. intake and ext
header matched !! 5 angle valve job
100lb springs .poly seals. EGR ports filled
ported lower
70 mm t.body & upper intake
d.roller timming chain. and button
ARP head bolts
bullit v.block
EGR block off
champ valve covers , breathers
under drive pully
8.5 MSD wires vr5 plugs gap .30
driver poly motor mount
pass stock replaced
short block all orig never been removed 47k miles
all parts have less then 50 miles on them . as u can see from the pics
everything is fresh ! i have a 210-215 roller cam i never installed
TRANS
200r4 brf factory trans w.stage 1 shift kit
3400 lockup 10"
trans cooler
H.D u joints
poly trans mount ( never installed )
REAR
8.5 posi 3.42 gear
eaton center section
seals , bearings , ARP 2.5" wheel studs
Soft shoes . s10 cylinders, hardwear kit
SUSPENSION
H&R upper and lowers
kyb f&r shocks
eibach drop springs
poly sway bar bushings
poly rear housing bushings ( not installed )
front pads and calipers ( stock)
FUEL
60lb injectors
accufab fuel reg & gauge
walbro 340 pump
hot wire kit
INTAKE & EXHAUST
super extreme front mount
3" down pipe w/46mm gate
3" SS cat back
Kenny Bell Headers S.S.
3" flow tube
3 1/2" maf tube
3 1/2" LS1 maf
4" K&N filter
PT5469 w/.82 housing
COOLING
f.body rad
ramcharger duel fans
scanmaster 2.1
pro fec b boost controller
PLX wide band
oil , tach and boost gauges
GEN 2 w/extreme G chip
PAINT
stripped to metal
int removed 3base 3clear
car was orig silver i had it two toned
glass fillers.
all soft seal weather stripping
4 front GTA striped
painted color of the car base clear high heat
polished lips
tires
225/60/16 fronts
295/50/16 rears (mickey thompson drags )
never any rust. or damage
car has never been tuned or raced
if u are looking for a daliy driver please dont buy this
she needs a warm home ,love and care
please feel free to ask for any other info
thank you
