1987 Buick T-Type
1NASTY69Z
1987 T-Type,just turned 90,000 miles.2nd owner,my next door neighbor the first.I have window sticker,and some other documentation.Re-painted about 4 yrs ago,taken to bare metal,quarter windows,door locks,door handles etc. removed and painted. Car was never hit just had some light door dings.Clean Carfax,Auto Check. Stock motored car,only Comp 980 springs installed,other than that bone stock motor. Runs consistant 10.90's 11.00's. from 119 to 121mph. Has been 1.52 60ft's on a 28x9 M/T slick. Has been 1.53 60ft on M/T drag radial. Clean car and reliable. A/C converted to 134,blows cold,and all power options work.NO ROLLBAR. The only reason Im listing the car is because I found something else I want to buy. I dont want to hear how bad the economy is,I dont care. If the other car sells before mine,I may just keep mine. I have nothing to hide on this car. Please only serious inquires. No picture collectors.I dont mean to sound like a jerk,but I have limited time on the computer to be sending pics and answering questions if you are not serious about the car.I have alot of the stock parts to go with the car.Heres some more on the car,Im sure I will forget something. Asking $13500
Body...
Paint 3-4 years old
Fiberglass bumpers and aluminum supports.Have stockers also
New outer window strips
New GM headlight bezels
New GM front bumper fillers
Back bumper fillers are in great condition.
One piece front air dam(have stockers)
GM GN rear spoiler
New bright white headlights
New windshield
Eibach lowering springs
NO FRAME NOTCH OR FENDER ROLL
Interior....
New headliner
VDO boost,temp.,oil press.,gauges
Motor...
Stock..COMP 980's
Trans...
Brand new from Brian Hofer
Billet everything
Fully rollerized
Stage Right trans brake
Just installed from a freshen up about 2 weeks ago,has about 3 miles on it.
Rear...
Factory GM 10 bolt
Checked for straigthness axle tubes welded
Moser 33 spline axles,spool,C-Clips
Brand new 3.42 gear set,and all new bearings
Moser Billet yoke
S-10 Wheel cylinders
Kirban big brake upgrade
T/A rear girdle
Poly upper bushings installed
Inland Empire 3 1/2 inch aluminum drive shaft
Metco loop
Fuel system...
50lb injectors
340 Walbro pump/with hot wire kit
Other stuff...
TE-61 Turbo from Limit Engineering
Precision Front Mount Intercooler
Brand new stock radiator
Dual Ramchargers fans
RJC Power plate
RJC Boost Control
Terry Houston 3inch Down pipe
3 inch single shot exhaust
LS1 MAF/with translator
TR Parts Big Mouth Cold Air kit
New rotors/front brakes
New Heater Core
Kirban Fuel Pressure Regulator
Scan Master
Turbo Tweak chips
10 inch Pats 3200 Converter
2 1/2 inch Kirban cross over pipe
4 brand new Comp Engineering shocks
Razors Alky Control
Linelock
ATR rear sway bar
UMI non adj. lower control arms
UMI adjustable uppers
Brand New 3 piece American Racing Trak Star wheels 15x4 15x8/4inch backspacing with 275/60/15 M/T drag radials
I have alot more pics...Convo pros are sold...new wheels on the car now.
Thanks...Yep wheels in second pic are the ones... here ya go...
Sorry,I guess that would be nice to know.... Pa. about 50 minutes from Killadelphia...I mean Philadelphia.
The car looks awesome Jim.
If only I had more room!:D
Good luck with the sale!
Brian
This is a very nice car -- I saw it at Kirban's. Also, these guys know how to tune! Good luck!
NICE car!! Love the color.
Someone is going to be getting a hell of a car for the money here.
Free bump for you. Good luck.
Bryan
