New update 2-14-18 at end of ad.
I took ownership of it in October of 2012 with 84k on the clock as you can see i don't get to drive it nearly enough as it only has 87k today. In addition i have a bunch of paperwork from the original owner and the 2nd owner i bought it from.
The original ad is still up here:
https://www.turbobuick.com/threads/87-limited-t-83k-original-miles-leather-stock.379215/
When i negotiated the car with him i had him fix the rust on the bottom seams of both doors as well as the rust on the the lower quarter behind the wheel. He owns a mustang restoration shop so all work was done professionally. He even used the correct coating on the lower quarters that the factory did to resits rocks and debris. As the car sits today there is no rust/rot anywhere.
Since then I've done the following:
Added a scanmaster
New Alradco Aluminum radiator
LT1 MAF and Maf Translator 2
Replaced the turbo back to a stock turbo from a 37k Grand National
8" Cold Air Filter
Caspers Hot Wire Fuel Pump Harness
Caspers Headlight Harness
237 Fuel Pressure Regulator to up pressure a little
New lowering springs and all new shocks all around.
Newer GM AM/FM Cassette Monsoon Radio and upgraded the 4x10s in the rear deck
Fixed the antenna so it goes all the way down but after radio upgrade can't get it to go back up. Still have original radio and all original parts that were replaced.
In August of 2015 I had Bison Performance in CT do the following:
Rear Main Seal Replaced
New 100lb valve springs installed
Timing chain replaced
Roller cam button replaced
36lb Injectors installed
New Crank Sensors
New Spark plugs (CR43ts)
Turbo Tweaks 5.7 Chip to match the injectors.
During Summer 2017:
Full Vacuum Brake Conversion with correct pedal, new booster, new master,
EBC Slotted front rotors, EBC red stuff pads.
New Prop Valve, new Master to Prop Valve Lines.
Stainless steel brake hoses all around.
UPDATE - 2/14/2018
Added a scanmaster
8" Cold Air Filter
New Crank Sensors
During Summer 2017:
UPDATE - 2/14/2018
- New 1-piece spoolfool rear filler installed and painted, along with new rear chrome bumperettes and new rubber to replace the cracking original fillers.
- A/C will be fixed and converted to r134a with all NEW AC/Delco parts including new compressor, accumulator/dryer, Orifice Tube, clutch switch and r134a fittings.
- Have a quote to get the vinyl roof redone, if i get to that the price is pretty firm, if the buyer doesn't care, i am negotiable a bit, but have already just put in another $1000 worth of new parts,paint and labor.
- AC replaced/converted/charged and cooling as it should now.
