BowtieBrat
- Aug 10, 2008
94 Pro Street,ProCharged,Pro Charged Camaro,1600 HP,easy 8 second street car.Car has been updated to look like a 2000.Car has power windows,cd player,tilt wheel,etc. and is street driven.Runs on E98 and NEVER gets hot.E98 is exactly as it sounds,over 98% ethanol.What does this mean for you? Extreme resistance to detonation, better cooling properties,and a cheap alternative for high HP applications! Not to mention 117+ octane.This Camaro is Top Notch,all the best,and is 100% street friendly.Comes with laptop that has as all the TUNES saved.Tunes were installed by Steve Morris of Steve Morris Racing Engines,known to most as the best when it comes to ProCharged set ups.There are street tunes saved as well as race tunes saved for the track.The car is easy to drive and hooks hard and goes straight.The best actual time was 5.30 @ 144mph,and backed up with another 5.32 pass.This was on a mild conservative tune.This was on Hoosier Quick Time Pro street tires.Has never been run with just slicks.Car has plenty of potential to get in the 4's easily.Tuning is done via MSD 7535 Programmable box.This car 95% of the time was driven around town, to Cruise Ins, car shows and to dinner.It's ready to race or just cruise around town.Like I mentioned earlier this car is set up to run on E98 which is only $4.00 a gallon here.Sure beats paying $18.00 a gallon for Race Fuel.There was over $125,000.00 spent building this car !! You will not be disappointed !!
ENGINE: 9:1 Comp./444 c.i.(4.2 Bore/ 4.0 Stroke)
-DART Rocket block,raised cam,wider pan rails.
-Brodix -12 heads (cnc -15 degree)2.18-or-2.20 Int. valves
*Heads flowed off the charts.
-JE pistons (custom)
-Brodix HVH intake all Ported by Steve Morris
-custom built headers
-Stefs custom built Oil pan,
-Callies Billet Crank .
-Oliver 6" Rods Billet,
-SMRE custom Grind Cam
-T&D shaft Rockers,
-Billet Oil Pump,
-F3 ProCharger
Other:
- C&S Blow-Thru carb.
-Magna Fuel Pro-Star 750 Fuel pump (good to 2,500HP)
-10 Line
-All Aero Space Disc Brakes
-Braced Custom 9" Ford Rear / 3:60 Pro Gear/
-Strange Aluminum Center Section
-Moser 40 Spline Gun Drilled Axles
- QA-1 Front & back
- Pro Mod 4 Link,Joints , bars etc.
- Dyna tech Custom Drive shaft
- Pro Mod Power Glide all Billet Internals with Pro Tree Brake
- PTC convertor
- Hurst Quarter Stick
- Line Lock
- XS Battery
- MSD Dyna Force 160 Amp Billet alternator
- Billet Vacuum Pump with Regulator's
- Dual Funny Car cage
- Kirkey seats
- Weld wheels
- 31x18.5 Hoosier Quick Time Pro's
- Aerospace brakes
- 16 gallon fuel cell
- Auto Meter Gauges
http://www.youtube.com/watch?v=XxPJo...ature=youtu.be
http://www.youtube.com/watch?v=K6AvK...ature=youtu.be
Extras that come with the car are 2 pulley's,extra ProCharger belt,an unopened 55 gallon drum of E98 fuel,and laptop W/Tunes.I am located in Indianapolis,Indiana and I have clear title in hand.The price is $35,000.00
-T&D shaft Rockers,
-Billet Oil Pump,
-F3 ProCharger
Other:
-10 Line
- QA-1 Front & back
- PTC convertor
- Line Lock
- XS Battery
- Kirkey seats
- Weld wheels
- Aerospace brakes
- Auto Meter Gauges
