1999 buick regal gs
ringman
Just bought a 99 regal gs with 120k miles completely stock. What do you recommend for a few hundred dollars of mods. Would like to have low 14 second potential, also curious reliability of transmission etc. I race an 87 gn and so this 99 buick will be my daily driver.
Do all the maintenance stuff...fluids, filters, plugs, wires
Most run high 14's stock so it doesn't take much...you could do an air filter and a downpipe or headers. That'd get you around 14.5s, plus a little bump in MPG. Then a tune and a smaller pulley would get you easy low 14/high 13
After the maintenance, a few mods could net you low 14's easy. It won't take much. Though, our transmissions are pretty much glass. Then again, these cars have ZERO traction, so your trans should be good.
I have had decent luck with these trannys just dont do smoky burnouts ,spin around corners ,etc.. keep the abuse to all business straight forward.
my wifes gs bone stock with a K&N ran 14.4 @ 96 for me and I have seen several others run similar that close to stock.
my daily driver has 211,000 miles and close to 200 passes in the 13's mostly on dr's and all on original trans pb of 13.5 @104 and 13.1 @109 on spray for that car , I got it to run 13.9 on the stock pulley and the 13.5 was on a 3.5 pulley ,plog ,3" dp & catback , ported rear ,st 1 tb
best spent couple hundred... probably u bend & res delete , used powerlog , 3.6 mps - in the right hands ( someone who has raced w bodies a lot) with proper track prep it would be flirting with 13.99 for a couple hundred
Thanks guys, good stuff to hear, I found zz performance website, turns out I work down the road from them. Anyways thinking of doing there stg 2 kit, which is 3.5" pulley system, thermostat, plugs, downpipe, air inake system and pcm for 600, says to expect 40hp gains, should I do that or are there cheaper and better ways?
zzp is the major vendor in the 3800 market at this point , they are a good vendor , I have bought tihngs from them in the past but prefer to buy used mods over new for bang for the buck now.
They are also in the business of selling parts whereas your fellow members will tend to look out for your best interests.
I do not like most vendors packages and there are some that are pretty dangerous - 3800 performance in particular...
a 3.5 pulley on stock manifolds is not a good idea , some gtp's can get away with it ( you clicked on the image of a gtp on zzp's site to get to 3800 stuff , the vast majority of modded 3800's are gtp's) gtp's have dual exit exhaust with 2 restrictive mufflers vs. a regal gs's 1 restrictive muffler so even though gtp guys will say their stock catback is a restriction a regal gs is much worse.
not enough exhaust to let out the extra air you are forcing in with an intake and smaller pulley causes boost stacking which generally increases detonation
for $600 I would look at the ebay headers which are slp knockoffs for $300 , a homemade 4" intake with K&N cone for $70
a modular pulley system with a 3.5 or 3.6 pulley for $75 or so used
and a zzp pcm for $100 unless you have someone local with a tuner thats willing - consider dropping the coin for a tuner yourself sooner rather than later
When you ran 13.9 on the stock pulley, how much timing did you run?? and what other changes did you make to your tune? Did you spray?
well here is the whole story on the 13.9 stock pulley , if you search regal gs vs gn on you tube you will see 4 passes with my car against an IC'ed gn with downpipe & maf translator ( thats what he said he had anyway...) one of the vids is linked in my sig
he kept messing with his tune to try to beat me and couldnt and we kept grudging - obviously not a member on here or he would have handed me my ass ;) for the 4th pass which was just before the track closed I offered to toss my stock pulley on which would drop my boost and de tune my car , I made no tuning changes and this was long before I started spraying that car , timing was probably around 16* dont remember for sure. it was also my worst 60 foot of the night - somewhere in the 2.3's as the dew had settled on the track
I am pretty confident I could get the car to 13.65-13.80 on the stock pulley with a decent 60 and some timing - it still trapped close to 102 as I recall (101.8/101.9)
13.9 on a stock pulley.... What were your short times, and how did you achieve them? What fuel did you use? What other mods did you have with that pulley? T-stat? What was your AFR and timing? What tires were you on, and what were the ambient air temps?
my best suggestion is buy used good parts off of clubGP for the cheap. Headers, rockers (if you wanna change your Valve cover gaskets might as well get rockers and a cheap set of springs) and a pulley (intake is simple) and some tuning. leave it at that, and just be semi nice to the transmission. definitely should get you up the the 13s
the cars have potential. I went 12.8 at 107 without an intercooler this year, no spray, 2.0 60'... few more details left out of course, but you get the idea.
my best suggestion is buy used good parts off of clubgp for the cheap. Headers, rockers (if you wanna change your valve cover gaskets might as well get rockers and a cheap set of springs) and a pulley (intake is simple) and some tuning. Leave it at that, and just be semi nice to the transmission. Definitely should get you up the the 13s
the cars have potential. I went 12.8 at 107 without an intercooler this year, no spray, 2.0 60'... Few more details left out of course, but you get the idea.
e85 ??
