ES1,
No Scantool here. No aftermarket DP. No aftermarket turbo. Stock IC with Dutt neck. Just a big fuel pump(340) w/hot wire and injectors(50lbs) with a stock fuel press reg. and a homemade CAI with T+ w/Extender chip. 2 1/2" Test pipe and dual ATR exhaust. Autolite 24's gapped at 0.035.
Do you think my dyno numbers are low 246/308? I looked at the dyno sheets again and noticed that the car was pulled to 5,700rmps each time, I wonder if taking it to 6,000rpms would have made any different. According to the chip manual, the rev limit is set for 6,350 rpms.
Also, the extender chip manual says that all parameters are set based on 45psi of fuel. So I guess I NEED TO GET A fuel press reg and a gauge to adjust it. During the dyno session, I had to adjust the T+ MAF WOT dial to 5 (10% richer)...so I guess she needs fuel.
I hope this helps me. I just think this car should have more based on the mods that came with the car when I bought it...(except for the test pipe and the homemade cai kit)
Thanks ALL for helping me.
