Phoneguy
Cometic HG stress tester
- Aug 27, 2002
Re read what he wrote...it will only go to 5 psi now...Check the vacumn line to the fuel regulator, its hard to believe you blew a headgasket at 5 psi.
Bryan
SignUp Now!Re read what he wrote...it will only go to 5 psi now...Check the vacumn line to the fuel regulator, its hard to believe you blew a headgasket at 5 psi.
Probally vacumn line on the regulator, or vacumn issues thats why it wont go over 5 psi.Re read what he wrote...it will only go to 5 psi now...
Bryan
JUST GOT 1 GN HAD IT OUT JUST PLAYING AND LEARNING THE CAR DID A COULPE BURN OUT AND NOW WHEN I BREAK TORK IT IT MIGHT GET TO 5 LBS THE IT START PUTTIN AND BACKFIRING AND WONT GO GOOD I HEAR A LOUD SUCKING SOUND NEED HELP.
Nope. He said he can only get to 5lbs before it starts backfiring, AFTER he played with it doing burnouts. Not knowing these cars + doing burnouts = headgaskets going POOF!Check the vacumn line to the fuel regulator, its hard to believe you blew a headgasket at 5 psi.
riviera said:I look for broken vacum line nothing but I was geting gas out the fuel pressure regulator vacum port is this normal also is the driver side head gasket always the 1 that go bad
Ive had a blowed head gasket that with 20+ psi never backfired, but had a dead miss in it, also never heard of a blowed head gasket making a hissing sound. I think he found the problem with the regulator, but i might not know these carsNope. He said he can only get to 5lbs before it starts backfiring, AFTER he played with it doing burnouts. Not knowing these cars + doing burnouts = headgaskets going POOF!
