Bowling Green special!
I have 2 units ready to bring to the Nats this year. If you are looking to save on shipping here is your deal!
These will both be the same.
BRF trans with parallel decked pump,550 & 400 boost valves, 10 vane pump, pump ring kit, the drum and input shaft are hardened (the drum is also welded to aid against breakage). Alto clutches and wide red band. The servo is upgraded to a custom built unit. And the trannies will have brakes. These units are both built to run into the 10`s, and will be great on the street, as well as strip.
$1600 with no core needed in return.
Feedback can be viewed in the feedback area on the board.
Thank you, Brian Hofer
hipsibri@cs.com
hipsibri@cs.com
