...... if i am having trouble holding the rear tires off the foot brake, this would help with me building boost without the tires spinning?
check out the videos, it definitely helps on my car.
B
SignUp Now!...... if i am having trouble holding the rear tires off the foot brake, this would help with me building boost without the tires spinning?
B
bob, this is sweet. so if i get this right, this will work ok with alky spraying, do to the fact its cutting timing out and not fuel thus no harm. if this is true sign me up please.
reason i ask if im on the trans brake on the line and the alky is spraying and the 2-step is killing spark it will be fine correct.
__________________
Don't get me wrong these look very fun and I'm sure I'll buy one!
...but couldn't all this be programmed in to the chip?
Reason I ask is my other car, (1993 eagle talon TSI) has this feature built into the chip. You just have to run one wire from the ECM to the clutch pedal to activate it. (could also be run to a brake pedal for autos) With the car off IGN on you change the stutter RPM with the TPS readings. It activates anytime it sees clutch/brake switch on and TPS over X percent with engine running.
Just a thought!
Sounds awesome !
Could a switch be rigged to the shifter that if we are in first, like us stagerite brakers, would engage it? May be a good idea, maybe???
Mike
.................Will this work with the MSD box?
No, its designed for the stock ignition system.
sure just make a little bracket so when the shifter is pulled all the way back it presses the button.mount it under the cover and that would be stealth![]()
