20+ year collection of 86-87 parts for sale.
do
Originally Posted by turbov6joe
Ok guys, here is list what I have for sale...I'll continue to add to the list as I think of it. Most all of the listed parts are used and off of an 86-87 TR unless listed otherwise. Please make me a REASONABLE offer for these parts + shipping and Paypal fees if applicable. Please don't waste our time with low ball offers, I'm not giving anything away. All parts are being sold AS IS.
OE 8445 heads (bare)
OE turbo crank .010/.010
OE TTA vacume block
OE TR vacume block (very rare)
OE rockers (3 sets)
OE turbo inlet hose
OE push rods
OE cam and matching lifters (confirmed good lobes)
OE TR radiators (3)
OE D5 converters (3)
OE TR starter
OE turbo oil drain line (2)
OE shifter assembly
OE TCC solenoid
OE ECM
OE MAF
OE charcoal canister
OE EGR plastic covers
OE dash vent inserts (4)
OE oil cooler lines
OE radiator fans (2)
OE upper plenum (2)
OE air filter box and plumbing
OE throttle body (2)
OE GN wheels (4)
OE GN center caps (6)
OE 2 dot rods (6)
OE pistons (17)
OE hood liner (decent condition, not perfect)
OE spare tires (3)
OE floor jacks (2)
OE F&R sway bars (2 each)
OE steel brake drums (2)
OE front rotors (2)
OE turbo shield
OE turbo inlet bell (2)
OE tranny pan
OE axles (checked perfect)
OE G80 Eaton Posi
OE TPS
OE fan relay #10018449
OE PCV valves #25095468 (3)
OE crossover pipe
OE serp belt tensioner pulley
OE 200-4R dust shield
OE injectors (6)
OE MAF (3)
OE TTA pinion gear
OE BRF tranny servo
OE oil filler pipe and cap (2)
OE intake elbow
OE crank pulley (2)
OE EGR valves (2)
OE EGR sensor
OE turbo oil feed line (2)
OE radiator cap
OE IAC
OE fuel regulator 233
OE A/C compressor (bad)
OE intercooler shroud
OE NOS knock sensor
OE hood emblems
OE GN fender emblems
OE water pumps (2)
OE Turbo-T horn madalion
OE door and package tray speakers
OE valve springs
A/C delete pulley
K&N valve cover breather w/ billet neck
Red Armstrong wires (3 sets)
Caspers heated O2 kit
9/11 converter (needs rebuilt, makes noise)
Aluminum water pump pulley
Mickey Thompson ET Street drag radials (2) 255/50/16 $350 shipped <10miles
Caspers HD fuel pump relay and wiring kit #102153 (New)
TRW forged pistons .030 over (6)
Turbo Tweek 6.0 chips for 50's (3) $50/chip
Dark Blue A piller trim, ECM cover, shifter handle.
u have any stock GN axles for sale ?
do
Yes, I have a set of 87 axles with ~52k miles on them.....I removed them before we started racing the car and replaced them with Mosers. Make a fair offer on them, as shipping might be a deal breaker.
List updated...These are the only parts I have for sale.
Make a reasonable offer + actual shipping. All parts are off of either a 1986 or 1987 GN, T, or TTA. Please text me with your needs at: 913-244-3829, I don't get on this page very often.
OE alt fan
OE starter heat shield
OE alt bracket (small)
OE turbo heat shield 2 (mounts on back of turbo in between the turbo & VC)
OE detent bracket (1)
OE rubber heat deflector under core support for intercooler
OE cat converter body heat shield
OE MAP sensor
OE 200-4R converter dust shield (1)
OE Coolant and washer fluid resevoirs (1 each)
OE lower IC mounting brackets (2) (the flat ones)
OE Buick valves (I/E) (numerous of each)
OE LC2 oil pan
OE IC up-pipes: 1 brushed stainless up-pipe & 1 black w/ alky nozzle.
OE turbo exhaust elbow w/spring bolts (unmodified...includes gasket)
OE R&L door handles (blackout)
OE TR vacume block
OE rockers (5 sets)
OE push rods (numerous)
OE TR starter (2)
OE turbo oil feed line (1)
OE charcoal canister (2)
OE oil cooler lines (1 set)
OE air filter box, plumbing, rubber snorkel & mounting bracket
OE throttle body (no sensors or boring)
OE 2 dot "turbo" rods (6)
OE Buick turbo pistons...LOOSE (6)
OE Buick turbo pistons on rods (6) with ARP wavelock bolts
OE floor jack (2)
OE front rotors (2)
OE turbo inlet bell (3)
OE turbo gaskets (2 new)
OE valve covers powder coated GN grey (nice, but not perfect)
OE oil fill tube w/ cap
OE D/S header (needs welded)
OE TR axles (confirmed straight)
OE PCV valves #25095468 (2 new)
OE TTA pinion gear
OE intake elbow
OE crank pulley (1)
OE EGR valves (3)
OE EGR electronic sensor (2)
OE cam sensor cap (2)
OE grey steering column collar
OE valve springs
OE ECM chips 1986 and 1987 (2)
G-Body Parts turbo oil drain line kit (new)
Turbo waste gate bleeder with hoses (new)
Heated O2 kit (2)
Roller cam bearing (new)
VDO 0-260*F water temp gauge (2 5/16")
VDO oil pressure gauge (electrical)
Auto Meter Pro Comp Ultra-Lite 8-18 volt gauge (2 5/16")
Auto Meter Pro Comp Ultra-Lite A/F ratio gauge (2 5/16")
OE GN grey ECM cover (2)
Turbo Tweek 6.0 alky chips for 50's (3) (full wideband control of A/F ratio)
Dark Blue ECM cover pieces
Epitome 1986 GN 1:18th scale diecast car and racing trailer (boxes included)
Monogram 1:24th GN plastic model (unopened, still platic wrapped)
Numerous Turbo Regal and GN Hotwheels type cars (different series and models...email or call with requests)
Seasoned ARP head bolts
It's time to move out all the 86-87 OE and aftermarket parts that I've collected over the last 20+ years. Email, PM, or text me with your needs....too much stuff to list.
Joe
913-244-3829
Do you have the A/C compressor and how much ?
