20+ year collection of 86-87 parts for sale.
Updated
OE alt fan
OE starter heat shield
OE alt bracket (small)
OE turbo heat shield 2 (mounts on back of turbo in between the turbo & VC)
OE detent bracket (1)
OE rubber heat deflector under core support for intercooler
OE cat converter body heat shield
OE MAP sensor
OE T-Type horn center
OE 200-4R converter dust shield (1)
OE Coolant and washer fluid resevoirs (1 each)
OE Complete working powermaster (also includes pedal & firewall bracket).
OE lower IC brackets (2) (the flat ones)
OE Buick valves (I/E) (numerous of each)
OE LC2 oil pan
OE "BUICK" grill emblem
OE IC up-pipes: 1 brushed stainless up-pipe & 1 black w/ alky nozzle.
OE turbo exhaust elbow w/spring bolts (unmodified...includes gasket)
OE R&L door handles (blackout)
OE TR vacume block
OE rockers (5 sets)
OE push rods (numerous)
OE cam and matching lifters (confirmed good lobes)
OE TR radiator (3)
OE D5 converter (2)
OE TTA Z5 torque converter (12k miles)
OE TR starter (2)
OE turbo oil feed line (2)
OE charcoal canister (2)
OE EGR plastic covers
OE dash vent inserts (4)
OE oil cooler lines (1 set)
OE upper plenum "doghouse"
OE air filter box, plumbing, rubber snorkel & mounting bracket
OE throttle body (no sensors)
OE 2 dot "turbo" rods (6)
OE Buick turbo pistons (12)
OE hood liner (decent condition, not perfect...prefer local pick up only)
OE floor jack (2)
OE F&R sway bars (2 each)
OE steel brake drums (2)
OE front rotors (2)
OE turbo inlet bell (3)
OE turbo gaskets (2 new)
OE valve covers powder coated GN grey (nice, but not perfect)
OE front timing cover (unmodified)
OE oil fill tubes w/ caps (2)
OE D/S header (needs welded)
OE TR axles (checked perfect)
OE PCV valves #25095468 (2 new)
OE injectors (12) flowed & ballanced
OE TTA pinion gear
OE intake elbow
OE crank pulley (1)
OE EGR valves (3)
OE EGR electronic sensor (2)
OE cam sensor cap (2)
OE A/C compressor (bad)
OE grey steering column collar
OE door and package tray speakers
OE valve springs
OE ECM chips 1986 and 1987 (2)
G-Body Parts turbo oil drain line kit (new)
Turbo waste gate bleeder with hoses (new)
K&N valve cover breather w/ billet neck
9/11 lock up converter (needs rebuilt, 3800 stall)
Heated O2 kit (2)
Roller cam bearing (new)
VDO 0-260*F water temp gauge (2 5/16")
VDO oil pressure gauge (electrical)
Auto Meter Pro Comp Ultra-Lite 8-18 volt gauge (2 5/16")
Auto Meter Pro Comp Ultra-Lite A/F ratio gauge (2 5/16")
TRW forged pistons .030 over w/ two dot rods (6)
OE GN grey ECM cover (2)
Turbo Tweek 6.0 alky chips for 50's (3) (full wideband control of A/F ratio)
Dark Blue D/S A piller trim & ECM cover pieces (2)
Epitome 1986 GN 1:18th scale diecast car and racing trailer (boxes included)
Monogram 1:24th GN plastic model (unopened, still platic wrapped)
Numerous Turbo Regal and GN Hotwheels type cars (different series and models...email or call with requests)
Seasoned ARP head studs
List updated
OE alt fan
OE MAP sensor
OE LC2 oil pan
OE TR vacume block
OE rockers (5 sets)
OE TR radiator (3)
OE D5 converter (2)
OE TR starter (2)
OE floor jack (2)
OE front rotors (2)
OE TTA pinion gear
OE intake elbow
OE crank pulley (1)
OE EGR valves (3)
OE valve springs
Heated O2 kit (2)
List upfated
OE electric radiator fans (2)
OE alt fan
OE MAP sensor
OE LC2 oil pan
OE TR vacume block
OE rockers (5 sets)
OE TR radiator (3)
OE D5 converter (2)
OE TR starter (2)
OE floor jack (2)
OE front rotors (2)
OE oil fill tube w/ cap
OE TTA pinion gear
OE intake elbow
OE crank pulley (1)
OE EGR valves (3)
OE valve springs
Heated O2 kit (2)
How much for a oil filler pipe and cap, 4 center caps and the complete air filter assembly shipped to 29483
How much for a oil filler pipe and cap and the complete air filter assembly shipped to 29483
I have a deal pending on both items...I'll let you know if it falls through. Are you aware that the oil pipe is not OE, but the billet tube with a K&N filter??
No, thats what I already have. Interested in the air cleaner assembly. PM sent.
what size injecters?.... looking for 42.5 or 60s call me if you have 816-679-3372 thanks Cartez
Updated...looking to move this stuff!
Make a reasonable offer...parts must go!!
OE alt fan
OE MAP sensor
OE LC2 oil pan
OE TR vacume block
OE rockers (5 sets)
OE TR radiator (3)
OE D5 converter (2)
OE TTA Z5 converter (12k miles)
OE TR starter (2)
OE upper plenum "doghouse" (unported)
OE Buick turbo pistons...LOOSE (6)
OE Buick turbo pistons on rods with ARP wavelock bolts
OE hood liner (decent condition, not perfect...pick up only)
OE floor jack (2)
OE front rotors (2)
OE TTA pinion gear
OE intake elbow
OE crank pulley (1)
OE EGR valves (3)
OE valve springs
PTS 9-11 lock up converter (needs rebuilt, 3800 stall)
Heated O2 kit (2)
Dark Blue ECM cover pieces
I need two oem grand national wheels for a 1986 model.. How much ? Can u ship to Atlanta area ?
