20+ year collection of 86-87 parts for sale.
List updated...These are the only parts I have for sale.
Make a reasonable offer + actual shipping. All parts are off of either a 1986 or 1987 GN, T, or TTA.
OE electric radiator fans (2)
OE alt fan
OE starter heat shield
OE alt bracket (small)
OE turbo heat shield 2 (mounts on back of turbo in between the turbo & VC)
OE detent bracket (1)
OE rubber heat deflector under core support for intercooler
OE cat converter body heat shield
OE MAP sensor
OE T-Type horn center
OE 200-4R converter dust shield (1)
OE Coolant and washer fluid resevoirs (1 each)
OE lower IC mounting brackets (2) (the flat ones)
OE Buick valves (I/E) (numerous of each)
OE LC2 oil pan
OE "BUICK" grill emblem
OE IC up-pipes: 1 brushed stainless up-pipe & 1 black w/ alky nozzle.
OE turbo exhaust elbow w/spring bolts (unmodified...includes gasket)
OE R&L door handles (blackout)
OE TR vacume block
OE rockers (5 sets)
OE push rods (numerous)
OE cam and matching lifters (confirmed good lobes)
OE TR radiator (3)
OE D5 converter (2)
OE TTA Z5 converter (12k miles)
OE TR starter (2)
OE turbo oil feed line (1)
OE charcoal canister (2)
OE EGR plastic covers
OE dash vent inserts (4)
OE oil cooler lines (1 set)
OE upper plenum "doghouse" (unported)
OE air filter box, plumbing, rubber snorkel & mounting bracket
OE throttle body (no sensors or boring)
OE 2 dot "turbo" rods (6)
OE Buick turbo pistons...LOOSE (6)
OE Buick turbo pistons on rods (6) with ARP wavelock bolts
OE floor jack (2)
OE F&R sway bars (2 each)
OE steel brake drums (2)
OE front rotors (2)
OE turbo inlet bell (3)
OE turbo gaskets (2 new)
OE valve covers powder coated GN grey (nice, but not perfect)
OE oil fill tube w/ cap
OE D/S header (needs welded)
OE TR axles (checked perfect)
OE PCV valves #25095468 (2 new)
OE injectors (12) flowed & ballanced
OE TTA pinion gear
OE intake elbow
OE crank pulley (1)
OE EGR valves (3)
OE EGR electronic sensor (2)
OE cam sensor cap (2)
OE A/C compressor (bad)
OE grey steering column collar
OE door and package tray speakers
OE valve springs
OE ECM chips 1986 and 1987 (2)
G-Body Parts turbo oil drain line kit (new)
Turbo waste gate bleeder with hoses (new)
K&N valve cover breather w/ billet neck
PTS 9-11 lock up converter (needs rebuilt, 3800 stall)
Heated O2 kit (2)
Roller cam bearing (new)
VDO 0-260*F water temp gauge (2 5/16")
VDO oil pressure gauge (electrical)
Auto Meter Pro Comp Ultra-Lite 8-18 volt gauge (2 5/16")
Auto Meter Pro Comp Ultra-Lite A/F ratio gauge (2 5/16")
OE GN grey ECM cover (2)
Turbo Tweek 6.0 alky chips for 50's (3) (full wideband control of A/F ratio)
Dark Blue ECM cover pieces
Epitome 1986 GN 1:18th scale diecast car and racing trailer (boxes included)
Monogram 1:24th GN plastic model (unopened, still platic wrapped)
Numerous Turbo Regal and GN Hotwheels type cars (different series and models...email or call with requests)
Seasoned ARP head bolts
How much for the shifter handle,(need shifter stem also..if possible) and for the aluminum water pump pulley?
OE alt fan
OE MAP sensor
OE LC2 oil pan
OE turbo exhaust elbow w/spring bolts (unmodified...includes new gasket)
OE TR vacume block
OE rockers (5 sets)
OE TR radiator (3)
OE D5 converter (2)
OE TR starter (2)
OE floor jack (2)
OE front rotors (2)
OE PCV valve #25095468 (new)
OE TTA pinion gear
OE intake elbow
OE crank pulley (1)
OE EGR valves (3)
OE valve springs
Heated O2 kit (2)
how much for hot wire kit? how much for good set of wires? what mil. thank you Matt87we4
Do you still have the Dk blue ECM covers?
Sent from my iPhone using Turbo Buick
Heated O2 kit -Im assuming a complete kit
Auto Meter Pro Comp Ultra-Lite A/F ratio gauge (2 5/16")- And do both gauges come with all the needed wires and sensors. If so how much shipped to 19090
Looking for nice front fender liners. got any?
Conrad
