20+ year collection of 86-87 parts for sale.
GN rims
Joe,
I will try you again.
Would you sell a pair of the rims only?
Many thanks
Jim
Would you sell just the detent plate? Interested in the plate and the model pending more info/prices.
OE 200-4R complete shifter assembly w/ modified detent for T brake
Monogram 1:24th GN plastic model (unopened, still platic wrapped)
Let me look to see if I have an OE detent plate I can replace it with. If so, I will sell the modified plate seperate.
The complete shifter assembly: $50 + shipping
Monogram model: $20
Joe,
Many thanks
Jim
Jim,
As much as I know you want just 2 of them, my gut says to keep them in a set of 4 for now. I had a local guy call me yesterday who wants them pretty bad...problem is he has to sell the wife before he has the $$$.
How much for the d5 converter, oil drain and fill tube to the turbo shipped to 19090
Thanks,
Rems
Updated Again
OE alt fan
OE starter heat shield
OE alt bracket (small)
OE turbo heat shield 2 (mounts on back of turbo in between the turbo & VC)
OE Complete tranny shifter linkage (rod to pan)
OE rubber heat deflector under core support for intercooler
OE cat converter body heat shield
OE MAP sensor (2 bar)
OE T-Type horn center
OE 200-4R converter dust shield (2)
OE Coolant and washer fluid resevoirs (1 each)
OE Complete working powermaster (also includes pedal & firewall bracket).
OE lower IC brackets (2) (the flat ones)
OE Buick valves (I/E) (numerous)
OE LC2 oil pan
OE "BUICK" grill emblem
OE IC up-pipes: 1 brushed stainless up-pipe & 1 black w/ alky nozzle.
OE turbo exhaust elbow w/spring bolts (unmodified...includes gasket)
OE R&L door handles (blackout)
OE TR vacume block
OE rockers (5 sets)
OE push rods (numerous)
OE cam and matching lifters (confirmed good lobes)
OE TR radiator (3)
OE D5 converter (2)
OE TTA Z5 torque converter (12k miles)
OE TR starter (2)
OE turbo oil feed line (2)
OE charcoal canister (2)
OE EGR plastic covers
OE dash vent inserts (4)
OE oil cooler lines (1 set)
OE upper plenum "doghouse"
OE air filter box, plumbing, rubber snorkel & mounting bracket
OE throttle body (no sensors)
OE GN wheels (4) (not perfect, real nice w/ no dents, bends or curb rash)
OE 2 dot rods (6)
OE Buick turbo pistons (12)
OE hood liner (decent condition, not perfect...prefer local pick up only)
OE floor jack
OE F&R sway bars (2 each)
OE steel brake drums (2)
OE front rotors (2)
OE turbo inlet bell (3)
OE turbo gaskets (2 new)
OE valve covers powder coated GN grey (nice, but not perfect)
OE front timing cover (unmodified)
OE oil fill tubes w/ caps (2)
OE D/S header (needs welded)
OE 200-4R tranny pan
OE TR axles (checked perfect)
OE PCV valves #25095468 (2 new)
OE injectors (12) flowed & ballanced
OE TTA pinion gear
OE intake elbow
OE crank pulley (1)
OE EGR valves (3)
OE EGR electronic sensor (2)
OE cam sensor cap (2)
OE A/C compressor (bad)
OE grey steering column collar
OE door and package tray speakers
OE valve springs
OE ECM chips 1986 and 1987 (2)
G-Body Parts turbo oil drain line kit (new)
Turbo waste gate bleeder with hoses (new)
K&N valve cover breather w/ billet neck
9/11 converter (needs rebuilt, 3800 stall)
Heated O2 kit (2)
Roller cam bearing (new)
VDO 0-260*F water temp gauge (2 5/16")
Auto Meter Pro Comp Ultra-Lite 8-18 volt gauge (2 5/16")
Auto Meter Pro Comp Ultra-Lite A/F ratio gauge (2 5/16")
TRW forged pistons .030 over w/ two dot rods (6)
Walbro 304M fuel pump
Walbro 340M fuel pump
OE GN grey ECM cover (2)
Turbo Tweek 6.0 alky chips for 50's (3) (full wideband control of A/F ratio)
Dark Blue D/S A piller trim & ECM cover pieces (2)
Epitome 1986 GN 1:18th scale diecast car and racing trailer (boxes included)
Numerous Turbo Regal and GN Hotwheels type cars (different series and models...email or call with requests)
Seasoned ARP head studs
I have the complete shifter assembly with the T brake detent bracket...$50
OE alt fan
OE LC2 oil pan
OE TR vacume block
OE rockers (5 sets)
OE TR radiator (3)
OE D5 converter (2)
OE TR starter (2)
OE 2 dot rods (6)
OE floor jack
OE front rotors (2)
OE TTA pinion gear
OE intake elbow
OE crank pulley (1)
OE EGR valves (3)
OE valve springs
Heated O2 kit (2)
Add 2 OE detent brakets to the list.
OE alt fan
OE LC2 oil pan
OE TR vacume block
OE rockers (5 sets)
OE TR radiator (3)
OE D5 converter (2)
OE detent brackets (2)
OE TR starter (2)
OE GN wheels (4) (DEAL PENDING)
OE 2 dot rods (6)
OE floor jack
OE front rotors (2)
OE TTA pinion gear
OE intake elbow
OE crank pulley (1)
OE EGR valves (3)
OE valve springs
Heated O2 kit (2)
List updated
OE alt fan
OE detent bracket (1)
OE MAP sensor
OE 200-4R converter dust shield (1)
OE Buick valves (I/E) (numerous of each)
OE LC2 oil pan
OE TR vacume block
OE rockers (5 sets)
OE TR radiator (3)
OE D5 converter (2)
OE TR starter (2)
OE 200-4R complete shifter assembly (does not include floor plate)
OE 2 dot "turbo" rods (6)
OE floor jack (2)
OE front rotors (2)
OE TTA pinion gear
OE intake elbow
OE crank pulley (1)
OE EGR valves (3)
OE valve springs
9/11 lock up converter (needs rebuilt, 3800 stall)
Heated O2 kit (2)
VDO oil pressure gauge (electrical)
Walbro 304M fuel pump (205lph)
Walbro 340M fuel pump (255lph)
