20+ year collection of 86-87 parts for sale.
I'm woefully unfamiliar with the subtle differences between GN and TTA motors. If the fuel pressure regulator is compatible, I'm interested. Price shipped to 90260?
I don't see a MAF on your list, sadly.
The major differences between the TR and TTA motors were:
Crank (TTA was cross drilled for better oiling, both had rolled fillets)
TTA blocks wear an "SG1" casting
TTA heads are different (smaller for a tighter engine space, flow better)
TTA Pistons are slightly different
TTA's all had SPS fasteners (as good or better than ARP)
The FP regulator is the same. I have sold all my MAF's...sorry.
Updated
All parts are used and off of an 86-87 TR unless otherwise stated....please make a reasonable offer on parts. Paypal gladly accepted with 3% fee added to total. I'm ready to move this stuff...make offers!
Call Joe for info: 913-244-3829. Will consider trading parts for guns (Looking for a 12ga side x side & ???)
OE MAP sensor
OE alternator bracket (small)
OE T-Type horn center
OE 200-4R converter dust shield (2)
OE Coolant and washer fluid resevoirs (1 each)
OE Complete working powermaster set-up.
OE lower IC brackets (2 the flat one)
OE 8445 heads (bare)
OE Buick valves (I/E)
OE LC2 oil pan
OE "BUICK" grill emblem
OE IC up-pipes: 1 chrome up-pipe,1 black up-pipe with alky nozzle.
OE turbo exhaust elbow w/spring bolts (unmodified)
OE R&L door handles (blackout)
OE TR vacume block
OE rockers (3 sets)
OE push rods (numerous)
OE cam and matching lifters (confirmed good lobes)
OE TR radiator (3)
OE D5 converter (2)
OE TTA Z5 torque converter (12k miles)
OE TR starter (2)
OE turbo oil feed line (2)
OE 200-4R shifter assembly w/ modified detent
OE charcoal canister (2)
OE EGR plastic covers
OE dash vent inserts (4)
OE oil cooler lines (1 set)
OE upper plenum "doghouse"
OE air filter box, plumbing, & mounting bracket
OE throttle body (no sensors)
OE GN wheels (4) (not perfect, but no dents, bends or curb rash)
OE GN center caps (8) Very good condition
OE 2 dot rods (6)
OE Buick turbo pistons (12)
OE hood liner (decent condition, not perfect...prefer local pick up only)
OE spare tire
OE floor jack
OE F&R sway bars (2 each)
OE steel brake drums (2)
OE front rotors (2)
OE turbo inlet bell (3)
OE turbo gaskets (2 new)
OE valve covers powder coated GN grey (decent condition, but not perfect)
OE front timing cover
OE oil fill tubes w/ caps (2)
OE D/S header (needs welded)
OE 200-4R tranny pan
OE TR axles (checked perfect)
OE MAP sensor
OE PCV valves #25095468 (2 new)
OE 200-4R dust shield (2)
OE injectors (12) flowed & ballanced
OE TTA pinion gear
OE intake elbow
OE crank pulley (1)
OE EGR valves (3)
OE EGR electronic sensor (2)
OE cam sensor cap (2)
OE A/C compressor (bad)
OE hood emblems (cracked) (2)
OE grey steering column collar
OE door and package tray speakers
OE valve springs
OE GN lug nuts (2 sets)
OE ECM chips (2)
G-Body Parts turbo oil drain line kit (new)
Turbo waste gate bleeder with hoses (new)
K&N valve cover breather w/ billet neck
9/11 converter (needs rebuilt)
Heated O2 kit (2)
Roller cam bearing (new)
VDO 0-260*F water temp gauge (2 5/16")
Auto Meter Pro Comp Ultra-Lite 8-18 volt gauge (2 5/16")
Auto Meter Pro Comp Ultra-Lite A/F ratio gauge (2 5/16")
TRW forged pistons .030 over w/ two dot rods (6) (DEAL PENDING)
Walbro 304M fuel pump
Walbro 340M fuel pump
OE GN grey ECM cover (2)
Turbo Tweek 6.0 alky chips for 50's (3) (full wideband control of A/F ratio)
Dark Blue D/S A piller trim & ECM cover
Ol' school Kenne Bell ram air
Epitome 1986 GN 1:18th scale diecast car and racing trailer (boxes included)
Monogram 1:24th GN plastic model (unopened, still platic wrapped)
Numerous Turbo Regal and GN Hotwheels type cars (different series and models...email or call with requests)
Seasoned ARP head studs
How much for the OE Intercooler shroud ?
This does include the lower rubber scoop I assume.
no...there are two brackets located under the car for the shift cable.. 1 bolts to the tranny pan, and the other bolts to the side of the tranny shift shaft.
Valves & Stock Pistons
How much are you asking for the stock valves? Also do you have a set of OE oversized pistons?
Thanks Wayne
You wont know till you ask . How much for all four rims ? I completkley understand why you dont want to break them up
Thanks Wayne
To the best of my knowledge there is no such beast as "OE oversize pistons." Everything oversize is aftermarket....yes I have a set of TRW's in .030" but there is a deal pending on them.
A set of Buick I&E valves...$60 shipped.
Time to move parts.
No REASONABLE offer on these parts will be refused!
OE MAP sensor
OE alternator bracket (small & large)
OE lower IC brackets (2)
OE LC2 oil pan
OE TR vacume block
OE rockers (3 sets)
OE TR radiator (3)
OE D5 converter (2)
OE TR starter (2)
OE 2 dot rods (6)
OE spare tire
OE floor jack
OE front rotors (2)
OE valve covers powder coated GN grey (nice condition, but not perfect)
OE front timing cover (unmodified)
OE TTA pinion gear
OE intake elbow
OE crank pulley (1)
OE EGR valves (3)
OE valve springs
OE ECM chips (2)
9/11 converter (needs rebuilt, 3800 stall)
Heated O2 kit (2)
