20+ year collection of 86-87 parts for sale.
Updated
All parts are used and off of an 86-87 TR unless otherwise stated....please make a reasonable offer I'm tired of looking at this stuff.
Paypal accepted with 3% fee added.
OE T-Type horn center
OE 200-4R converter dust shield (2)
OE Coolant and washer fluid resevoirs (1 each)
OE Complete working powermaster set-up.
OE lower IC brackets (1)
OE 8445 heads (bare)
OE Buick valves (I/E)
OE LC2 oil pan
OE "BUICK" grill emblem
OE IC up-pipes: 1 chrome up-pipe,1 black up-pipe with alky nozzle.
OE turbo crank .010/.010 (needs polished)
OE turbo exhaust elbow w/spring bolts
OE R&L door handles (blackout)
OE TR vacume block (2)
OE rockers (3 sets)
OE turbo inlet hose
OE push rods (numerous)
OE cam and matching lifters (confirmed good lobes)
OE TR radiators (3)
OE D5 converters (2)
OE TTA Z5 converter (12k miles)
OE TR starters (2)
OE turbo oil feed line (2)
OE 200-4R shifter assembly
OE charcoal canister (2)
OE EGR plastic covers
OE dash vent inserts (4)
OE oil cooler lines (1 set)
OE upper plenum "doghouse" (1)
OE air filter box and plumbing
OE throttle body (1)
OE GN wheels (4)
OE GN center caps (8)
OE 2 dot rods (6)
OE turbo pistons (17)
OE hood liner (decent condition, not perfect...prefer local pick up only)
OE spare tire (1)
OE floor jack (1)
OE F&R sway bars (2 each)
OE steel brake drums (2)
OE front rotors (2)
OE turbo inlet bell (3)
OE valve covers powder coated GN grey
OE front timing cover
OE oil fill tubes w/ caps (2)
OE D/S header (needs welded)
OE 200-4R tranny pan
OE TR axles (checked perfect)
OE MAP sensor (1)
OE PCV valves #25095468 (2 new)
OE 200-4R dust shield
OE injectors (12) ballanced
OE TTA pinion gear
OE intake elbow
OE crank pulley (1)
OE EGR valves (3)
OE EGR electronic sensor (2)
OE cam sensor cap (2)
OE fuel pressure regulator 233
OE A/C compressor (bad)
OE hood emblems (2)
OE water pumps (3)
OE grey steering column collar
OE door and package tray speakers
OE valve springs
G-Body Parts turbo oil drain line kit (new)
Turbo waste gate bleeder with hoses (new)
PT&E HD (18psi) adjustable waste gate actuator w/bracket (new)
K&N valve cover breather w/ billet neck
9/11 converter (needs rebuilt)
Heated O2 kit (2)
Billet Aluminum water pump pulley
Roller cam bearing
Numerous ARP head bolt sets
VDO 0-260*F water temp gauge (2 5/16)
Auto Meter Pro Comp Ultra-Lite 8-18 volt gauge (2 5/16)
TRW forged pistons .030 over w/ turbo rods (6)
Walbro 304M fuel pump
Walbro 340M fuel pump (low miles)
OE GN grey ECM cover (2)
Turbo Tweek 6.0 chips for 50's (3)
Dark Blue D/S A piller trim, ECM cover
got the tensioner joe! thanks so much! how much for the valve cover breather? is it twist in like the stock oil fill or is it push in? I need 2 push in breathers for a set of buick power 6 tall valve covers. let me know how much shipped to 59714...thanks!
Let me check to verify and get back with you.
I sold the GN, TTA and the T. I know who has all 3 cars and they are in good hands. My dad still has his GN, matter of fact I'm getting ready to pull the motor and rebuild it. BW and I are in touch, but our lives kinda took us different directions so I don't see him or Neil much. I hope things get better for ya. Call me and we set up a time to P/U those parts. 913-244-3829
You said that just about perfect Joe. Awww, I miss you guys too! LOL. Life gets busy after kids dont it??????????????????
Joe, PM me about the converter, and the HD wastegate. TTYS
Do you have the Turbo oil feed line, or the fuel feed line and the fuel return line that go on the front of the engine and lead to the fuel rail? PM or email me at tsand0488@aol.com if you do please.
Updated
All parts are used and off of an 86-87 TR unless otherwise stated....please make a reasonable offer on all parts. Paypal gladly accepted with 3% fee added on to total.
OE alternator bracket (small)
OE LC2 oil pan
OE rockers (3 sets)
OE turbo inlet hose
OE TR radiators (3)
OE TR starters (2)
OE GN wheels (4)
OE 2 dot rods (6)
OE spare tire (1)
OE floor jack (1)
OE front rotors (2)
OE MAP sensor (1)
OE TTA pinion gear
OE intake elbow
OE crank pulley (1)
OE EGR valves (3)
OE hood emblems (2)
OE water pumps (3)
OE valve springs
Heated O2 kit (2)
Roller cam bearing (new)
Numerous ARP head stud sets
Updated
OE LC2 oil pan
OE rockers (3 sets)
OE turbo inlet hose
OE TR radiator (3)
OE D5 converter (2)
OE TR starter (2)
OE GN wheels (4)
OE 2 dot rods (6)
OE spare tire (1)
OE floor jack (1)
OE front rotors (2)
OE MAP sensor (1)
OE injectors (12) flowed & ballanced
OE TTA pinion gear
OE intake elbow
OE crank pulley (1)
OE EGR valves (3)
OE hood emblems (cracked) (2)
OE water pumps (3)
OE valve springs
OE GN lug nuts (2 sets)
OE ECM chips (2)
G-Body Parts & Stuff turbo oil drain line kit (new)
Heated O2 kit (2)
VDO 0-260*F water temp gauge (2 5/16")
Auto Meter Pro Comp Ultra-Lite 8-18 volt gauge (2 5/16")
Auto Meter Pro Comp Ultra-Lite A/F ratio gauge (2 5/16")
TRW forged pistons .030 over w/ two dot rods (6)
Dark Blue D/S A piller trim & ECM cover
Ol' school Kenne Bell ram air
how much for driverside plastic drip rail, tri shield horn medallion, and 4 door pull strap covers, good window felt? Shipped to MN 55443
Phil
Phil
Phil,
None of the parts you are requesting are on the list above...that's all I have for sale.
