20+ year collection of 86-87 parts for sale.
Hey Joe,
billet water pump pulley still available? you gonna make it to BG?
Nick
Interested in:
OE IC up-pipes: 1 chrome up-pipe,1 black up-pipe with alky nozzle.
OE upper plenum "doghouse" (1)
Pics?
Updated
All parts are used and off of an 86-87 TR unless otherwise stated....please make a reasonable offer on all parts. Paypal gladly accepted with 3% fee added on to total.
OE alternator bracket (small)
OE T-Type horn center
OE 200-4R converter dust shield (2)
OE Coolant and washer fluid resevoirs (1 each)
OE Complete working powermaster set-up.
OE lower IC brackets (1)
OE 8445 heads (bare)
OE Buick valves (I/E)
OE LC2 oil pan
OE "BUICK" grill emblem
OE turbo exhaust elbow w/spring bolts
OE R&L door handles (blackout)
OE TR vacume block (2)
OE rockers (3 sets)
OE turbo inlet hose
OE push rods (numerous)
OE cam and matching lifters (confirmed good lobes)
OE TR radiator (3)
OE D5 converter (2)
OE TTA Z5 converter (12k miles)
OE TR starter (2)
OE turbo oil feed line (2)
OE 200-4R shifter assembly
OE charcoal canister (2)
OE EGR plastic covers
OE dash vent inserts (4)
OE oil cooler lines (1 set)
OE air filter box and plumbing
OE throttle body (1)
OE GN wheels (4)
OE GN center caps (8)
OE 2 dot rods (6)
OE turbo pistons (17)
OE hood liner (decent condition, not perfect...prefer local pick up only)
OE spare tire (1)
OE floor jack (1)
OE F&R sway bars (2 each)
OE steel brake drums (2)
OE front rotors (2)
OE turbo inlet bell (3)
OE valve covers powder coated GN grey
OE front timing cover
OE oil fill tubes w/ caps (2)
OE D/S header (needs welded)
OE 200-4R tranny pan
OE TR axles (checked perfect)
OE MAP sensor (1)
OE PCV valves #25095468 (2 new)
OE 200-4R dust shield
OE injectors (12) flowed & ballanced
OE TTA pinion gear
OE intake elbow
OE crank pulley (1)
OE EGR valves (3)
OE EGR electronic sensor (2)
OE cam sensor cap (2)
OE fuel pressure regulator 233
OE A/C compressor (bad)
OE hood emblems (cracked) (2)
OE grey steering column collar
OE door and package tray speakers
OE valve springs
OE GN lug nuts (2 sets)
OE ECM chips (2)
G-Body Parts & Stuff turbo oil drain line kit (new)
Turbo waste gate bleeder with hoses (new)
K&N valve cover breather w/ billet neck
9/11 converter (needs rebuilt)
Heated O2 kit (2)
Roller cam bearing (new)
Numerous ARP head stud sets
VDO 0-260*F water temp gauge (2 5/16")
Auto Meter Pro Comp Ultra-Lite 8-18 volt gauge (2 5/16")
Auto Meter Pro Comp Ultra-Lite A/F ratio gauge (2 5/16")
TRW forged pistons .030 over w/ two dot rods (6)
Walbro 304M fuel pump
Walbro 340M fuel pump
OE GN grey ECM cover (2)
Turbo Tweek 6.0 chips for 50's (3)
Dark Blue D/S A piller trim & ECM cover
Ol' school Kenne Bell ram air
Do you have a radio, waht type and condition-does it all work including casette?
Also looking for left seal that seals t top and runs down rear or windshield piller wear the window seals up against it?
List Updated
All parts are used and off of an 86-87 TR unless otherwise stated....please make a reasonable offer on parts. Paypal gladly accepted with 3% fee added to total. I'm ready to move this stuff...make offers!
Call Joe for info: 913-244-3829. Will consider trading parts for guns (Looking for a 12ga side x side & ???)
OE LC2 oil pan
OE TR vacume block (1)
OE rockers (3 sets)
OE turbo inlet hose
OE TR radiator (3)
OE D5 converter (2)
OE TTA Z5 torque converter (12k miles)
OE TR starter (2)
OE GN wheels (4) (not perfect, but no dents, bends or curb rash)
OE GN center caps (8) Very good condition
OE 2 dot rods (6)
OE Buick turbo pistons (17)
OE spare tire (1)
OE floor jack (1)
OE front rotors (2)
OE valve covers powder coated GN grey (decent condition, but not perfect)
OE MAP sensor (1)
OE TTA pinion gear
OE intake elbow
OE crank pulley (1)
OE EGR valves (3)
OE valve springs
OE ECM chips (2)
Heated O2 kit (2)
TRW forged pistons .030 over w/ two dot rods (6) (DEAL PENDING)
Turbo Tweek 6.0 alky chips for 50's (3) (full wideband control of A/F ratio)
Epitome 1986 GN 1:18th scale diecast car and racing trailer. Have original boxes and paperwork.
Monogram 1:24th GN plastic model (unopened, still platic wrapped)
Numerous Turbo Regal and GN Hotwheels type cars (different series and models...email or call with requests)
Seasoned ARP head studs
I'm woefully unfamiliar with the subtle differences between GN and TTA motors. If the fuel pressure regulator is compatible, I'm interested. Price shipped to 90260?
I don't see a MAF on your list, sadly.
