turbov6joe
Signal 1 J-12
- May 22, 2002
Updated
All parts are used and off of an 86-87 TR unless otherwise stated....please make a reasonable offer I'm tired of looking at this stuff.
Paypal accepted with 3% fee added.
OE 200-4R converter dust shield (2)
OE Coolant and washer fluid resevoirs (2 each)
OE Complete working powermaster set-up.
OE lower IC brackets (2)
OE 8445 heads (bare)
OE Buick valves (I/E)
OE LC2 oil pan
OE "BUICK" grill emblem
OE IC up-pipes: 1 chrome up-pipe,1 black up-pipe with alky nozzle.
OE turbo crank .010/.010 (needs polished)
OE turbo exhaust elbow w/spring bolts
OE R&L door handles (blackout)
OE shifter assembly
OE TR vacume block
OE rockers (3 sets)
OE turbo inlet hose
OE push rods (numerous)
OE cam and matching lifters (confirmed good lobes)
OE TR radiators (3)
OE D5 converters (2)
OE TTA Z5 converter (12k miles)
OE TR starters (2)
OE turbo oil feed line (2)
OE 200-4R shifter assembly
OE charcoal canister (2)
OE EGR plastic covers
OE dash vent inserts (4)
OE oil cooler lines (1 set)
OE radiator fans (3)
OE upper plenum "doghouse" (2)
OE air filter box and plumbing
OE throttle body (1)
OE GN wheels (4)
OE GN center caps (8)
OE 2 dot rods (6)
OE turbo pistons (17)
OE hood liner (decent condition, not perfect...prefer local pick up only)
OE spare tire (1)
OE floor jack (1)
OE F&R sway bars (2 each)
OE steel brake drums (2)
OE front rotors (2)
OE turbo shield (painted blue and uncut)
OE turbo inlet bell (3)
OE valve covers powder coated GN grey w/RJC spacers
OE front timing cover
OE oil fill tubes w/ caps (2)
OE D/S header (needs welded)
OE 200-4R tranny pan
OE TR axles (checked perfect)
OE TPS sensor
OE MAP sensor (2)
OE PCV valves #25095468 (3 new)
OE crossover pipe (2)
OE serp belt tensioner pulley
OE 200-4R dust shield
OE injectors (12) ballanced
OE TTA pinion gear
OE intake elbow
OE crank pulley (2)
OE EGR valves (3)
OE EGR electronic sensor (2)
OE cam sensor cap (2)
OE IAC
OE fuel pressure regulator 233
OE A/C compressor (bad)
OE intercooler shroud (2)
OE hood emblems (2)
OE water pumps (3)
OE grey steering column collar
OE door and package tray speakers
OE valve springs
Turbo waste gate bleeder with hoses
PT&E HD (18psi) adjustable waste gate actuator w/bracket (new)
K&N valve cover breather w/ billet neck
9/11 converter (needs rebuilt)
Heated O2 kit (2)
Aluminum water pump pulley
Roller cam bearing
Numerous ARP head bolt sets
VDO 0-260*F water temp gauge (2 5/16)
Auto Meter Pro Comp Ultra-Lite 8-18 volt gauge (2 5/16)
TRW forged pistons .030 over w/ turbo rods (6)
Walbro 304M fuel pump
OE GN grey ECM cover (2)
Turbo Tweek 6.0 chips for 50's (3)
Dark Blue A piller trim, ECM cover
OE LC2 oil pan
OE shifter assembly
OE TR vacume block
OE rockers (3 sets)
OE turbo inlet hose
OE TR radiators (3)
OE TR starters (2)
OE GN wheels (4)
OE 2 dot rods (6)
OE spare tire (1)
OE floor jack (1)
OE front rotors (2)
OE TPS sensor
OE MAP sensor (2)
OE TTA pinion gear
OE intake elbow
OE crank pulley (2)
OE EGR valves (3)
OE IAC
OE hood emblems (2)
OE water pumps (3)
OE valve springs
Heated O2 kit (2)
Roller cam bearing
