20+ year collection of 86-87 parts for sale.
Complete power master brake
Was a complete working unit when recently removed from an 1987 Turbo-T, comes with pedal and firewall bracket.
$225 shipped.
Updated
All parts are used and off of an 86-87 TR unless otherwise stated....please make reasonable offer.
Complete working powermaster set-up.
OE 8445 heads (bare)
OE Buick valves (I/E)
OE LC2 oil pan
OE "BUICK" grill emblem
OE IC up-pipes: 1 chrome up-pipe,1 black up-pipe with alky nozzle.
OE GN steering wheel (looks just "ok" but needs recovered to be show quality)
OE turbo crank .010/.010 (needs polished)
OE turbo exhaust elbow w/spring bolts
OE R&L door handles (blackout)
OE IC scoop leaf screens (3) near new condition
OE shifter assembly
OE door sill plates
OE TR vacume block
OE rockers (3 sets)
OE turbo inlet hose
OE push rods (numerous)
OE cam and matching lifters (confirmed good lobes)
OE TR radiators (3)
OE D5 converters (2)
OE TTA Z5 converter (12k miles)
OE TR starters (2)
OE turbo oil drain line (2)
OE turbo oil feed line (2)
OE 200-4R shifter assembly
OE charcoal canister (2)
OE EGR plastic covers
OE dash vent inserts (4)
OE oil cooler lines (1 set)
OE radiator fans (2)
OE upper plenum (2)
OE air filter box and plumbing
OE throttle body (2)
OE GN wheels (4)
OE GN center caps (8)
OE 2 dot rods (6)
OE turbo pistons (17)
OE hood liner (decent condition, not perfect...prefer local pick up only)
OE spare tire (1)
OE floor jack (1)
OE F&R sway bars (2 each)
OE steel brake drums (2)
OE front rotors (2)
OE turbo shield (painted blue and uncut)
OE turbo inlet bell (3)
OE valve covers powder coated GN grey w/RJC spacers
OE front timing cover
OE D/S header (needs welded)
OE 200-4R tranny pan
OE TR axles (checked perfect)
OE TPS sensor
OE MAP sensor (2)
OE PCV valves #25095468 (3 new)
OE crossover pipe (2)
OE serp belt tensioner pulley
OE 200-4R dust shield
OE injectors (12)
OE TTA pinion gear
OE oil filler pipe and cap (3) 1 SOLD
OE intake elbow
OE crank pulley (3)
OE EGR valves (3)
OE EGR electronic sensor (2)
OE cam sensor cap (2)
OE IAC
OE fuel regulator 233
OE fuel regulator 233 (adjustable)
OE A/C compressor (bad)
OE intercooler shroud (2) (1 complete with scoop and leaf screen)
OE hood emblems (2)
OE GN fender emblems (2)
OE water pumps (3)
OE Turbo-T steering wheel horn madalion
OE grey steering column collar
OE door and package tray speakers
OE valve springs
Turbo waste gate bleeder with hoses
PT&E HD waste gate actuator and bracket (new)
K&N valve cover breather w/ billet neck
Red Armstrong spark plug wires (3 sets of black)
9/11 converter (needs rebuilt)
Heated O2 kit
Aluminum water pump pulley
Roller cam bearing
Numerous ARP head bolt sets
VDO 0-260*F water temp gauge (2 5/16)
Auto Meter Pro Comp Ultra-Lite 8-18 volt gauge (2 5/16)
Braided SS turbo feed line
TRW forged pistons .030 over w/ turbo rods (6)
Walbro 304M fuel pump
OE GN grey ECM cover (2)
Turbo Tweek 6.0 chips for 50's (3) $50/chip
Dark Blue A piller trim, ECM cover, shifter handle.
Updated
OE LC2 oil pan
OE shifter assembly
OE door sill plates
OE TR vacume block
OE rockers (3 sets)
OE turbo inlet hose
OE TR radiators (3)
OE TR starters (2)
OE upper plenum (2)
OE GN wheels (4)
OE 2 dot rods (6)
OE spare tire (1)
OE floor jack (1)
OE front rotors (2)
OE TPS sensor
OE MAP sensor (2)
OE injectors (12)
OE TTA pinion gear
OE oil filler pipe and cap (2)
OE intake elbow
OE crank pulley (3)
OE EGR valves (3)
OE IAC
OE hood emblems (2)
OE water pumps (3)
OE valve springs
Red Armstrong spark plug wires (3 sets of black, like new)
Heated O2 kit
Roller cam bearing
Braided SS turbo oil feed line
Turbo Tweek 6.0 chips for 50's (3) $40/chip
GN Fender Emblems
Interested if the "innercooled" emblems are also included. If so how much shipped to 91331? Thanks.
Updated List
All parts are used and off of an 86-87 TR unless otherwise stated....please make reasonable offer. Paypal accepted with 3% fee added.
OE LC2 oil pan
OE shifter assembly
OE door sill plates
OE TR vacume block
OE rockers (3 sets)
OE turbo inlet hose
OE TR radiators (3)
OE TR starters (2)
OE radiator fans (3)
OE upper plenum "doghouse" (2)
OE throttle body (1)
OE GN wheels (4)
OE 2 dot rods (6)
OE spare tire (1)
OE floor jack (1)
OE front rotors (2)
OE TPS sensor
OE MAP sensor (2)
OE injectors (12)
OE TTA pinion gear
OE intake elbow
OE crank pulley (3)
OE EGR valves (3)
OE IAC
OE fuel pressure regulator 233
OE fuel pressure regulator 233 (adjustable)
OE hood emblems (2)
OE water pumps (3)
OE valve springs
PT&E HD (18psi) adjustable waste gate actuator w/bracket (new)
Heated O2 kit
Roller cam bearing
Updated
OE lower IC brackets (2)
OE LC2 oil pan
OE shifter assembly
OE TR vacume block
OE rockers (3 sets)
OE turbo inlet hose
OE TR radiators (3)
OE TR starters (2)
OE GN wheels (4)
OE 2 dot rods (6)
OE spare tire (1)
OE floor jack (1)
OE front rotors (2)
OE TPS sensor
OE MAP sensor (2)
OE injectors (12)
OE TTA pinion gear
OE intake elbow
OE crank pulley (3)
OE EGR valves (3)
OE IAC
OE hood emblems (2)
OE water pumps (3)
OE valve springs
Heated O2 kit
Roller cam bearing
Updated
OE 200-4R converter dust shield
OE Coolant and washer fluid resevoirs (2 each)
OE Complete working powermaster set-up.
OE LC2 oil pan
OE shifter assembly
OE TR vacume block
OE rockers (3 sets)
OE turbo inlet hose
OE TR radiators (3)
OE TR starters (2)
OE GN wheels (4)
OE 2 dot rods (6)
OE spare tire (1)
OE floor jack (1)
OE front rotors (2)
OE TPS sensor
OE MAP sensor (2)
OE injectors (12)
OE TTA pinion gear
OE intake elbow
OE crank pulley (3)
OE EGR valves (3)
OE IAC
OE hood emblems (2)
OE water pumps (3)
OE valve springs
Heated O2 kit (2)
Roller cam bearing
Updated
All parts are used and off of an 86-87 TR unless otherwise stated....please make a reasonable offer I'm tired of looking at this stuff.
OE 200-4R converter dust shield (2)
OE LC2 oil pan
OE shifter assembly
OE TR vacume block
OE rockers (3 sets)
OE turbo inlet hose
OE TR radiators (3)
OE TR starters (2)
OE GN wheels (4)
OE 2 dot rods (6)
OE spare tire (1)
OE floor jack (1)
OE front rotors (2)
OE oil fill tubes w/ caps (2)
OE TPS sensor
OE MAP sensor (2)
OE injectors (12) ballanced
OE TTA pinion gear
OE intake elbow
OE crank pulley (2)
OE EGR valves (3)
OE IAC
OE hood emblems (2)
OE water pumps (3)
OE valve springs
Heated O2 kit (2)
Roller cam bearing
