List updated again
OE 8445 heads (bare)
OE Buick valves (I&E)
OE oil pan
OE "BUICK" grill emblem
OE IC up-pipes: 1 chrome up-pipe,1 black up-pipe with alky nozzle, 1 OE
OE GN steering wheel (looks just "ok" but needs recovered to be show quality)
OE turbo crank .010/.010 (needs polished)
OE turbo exhaust elbow w/spring bolts
OE R&L door handles (black)
OE IC scoop leaf screens (3) near new condition
OE shifter assembly
OE door sill plates
OE TTA vacume block SOLD
OE TR vacume block
OE rockers (3 sets)
OE turbo inlet hose
OE push rods (numerous)
OE cam and matching lifters (confirmed good lobes)
OE TR radiators (3)
OE D5 converters (3)
OE TTA Z5 converter (12k miles)
OE TR starters (2)
OE turbo oil drain line (3) 1 SOLD
OE 200-4R shifter assembly
OE TCC solenoid SOLD
OE ECM SOLD
OE MAF SOLD
OE charcoal canister (2)
OE EGR plastic covers
OE EGR valves (4)
OE dash vent inserts (4)
OE oil cooler lines (2) 1 SOLD
OE radiator fans (2)
OE upper plenum (2)
OE air filter box and plumbing
OE throttle body (2)
OE GN wheels (4)
OE GN center caps (8)
OE 2 dot rods (6)
OE turbo pistons (17)
OE hood liner (decent condition, not perfect...local pick up only)
OE spare tires (3)
OE floor jacks (2) 1 SOLD
OE F&R sway bars (2 each)
OE steel brake drums (2)
OE front rotors (2)
OE turbo shield (painted blue and uncut)
OE turbo inlet bell (3)
OE valve covers powder coated GN grey w/RJC spacers
OE front timing cover
OE D/S header (needs welded)
OE 200-4R tranny pan
OE axles (checked perfect)
OE G80 Eaton Posi SOLD
OE TPS
OE fan relay #10018449 SOLD
OE PCV valves #25095468 (3)
OE crossover pipe (2)
OE serp belt tensioner pulley
OE 200-4R dust shield
OE injectors (12)
OE TTA pinion gear
OE BRF tranny servo SOLD
OE oil filler pipe and cap (3)
OE intake elbow
OE crank pulley (3)
OE EGR valves (3)
OE EGR sensor
OE turbo oil feed line (2)
OE radiator cap
OE IAC
OE fuel regulator 233
OE fuel regulator 233 (adjustable)
OE A/C compressor (bad)
OE intercooler shroud (2) (1 complete with scoop and leaf screen)
OE NOS knock sensor SOLD
OE hood emblems (2)
OE GN fender emblems (2)
OE water pumps (3)
OE Turbo-T steering wheel horn madalion
OE door and package tray speakers
OE valve springs
A/C delete pulley SOLD
K&N valve cover breather w/ billet neck
Red Armstrong spark plug wires (3 sets of black)
Caspers heated O2 kit (2) 1 SOLD
9/11 converter (needs rebuilt, makes noise)
Aluminum water pump pulley
Roller cam bearing
Numerous ARP head bolt sets
VDO 0-260*F water temp gauge (2 5/16)
Auto Meter Pro Comp Ultra-Lite 8-18 volt gauge (2 5/16)
Braided SS turbo feed line
Mickey Thompson ET Street drag radials DEAL PENDING
Caspers HD fuel pump relay and wiring kit #102153 (New) SOLD
TRW forged pistons .030 over (6)
Walbro 304M fuel pump
OE GN grey ECM cover (2)
Turbo Tweek 6.0 chips for 50's (3) $50/chip
Dark Blue A piller trim, ECM cover, shifter handle.
