Ken,
Try the car stereo stores for a wiring adapter. Metra is one brand.
Make sure that all the wires that are supposed to be there on the
new radio end of the harness are there. The one I got was missing
2 of the wires, though I haven't heard of anyone else having had
this problem. You'll also need an antenna adapter, from '89 on they
used a smaller pin on the antenna lead. I have a '01 Monsoon in my
85 SS and only needed to modify the radio brackets(stock and monsoon)
a little. By the way without the external amp the power output is 54
watts per channel if it's a Monsoon.
If you have any questions about what wires go where try
http://www.installdoctor.com for the stock diagram and
http://ls1.com
in the "Electronic/Radio.." FAQ's for the newer style('00 +) radio wiring. The "install doctor" wiring diagram for the later model radios is different than what you are going to have on the '02+ radio (more wires on the '00 and newer).
HTH.
Larry.
