2004R/400 TRANSMISSION PARTS
chris718
Original BRF valve body.$125.Original Turbo Trans Am valve body.$125.00.Original used 11 tooth orange governor gear.$39.New billet input shaft ,updated design.$149.00.New billet overdrive ring gear.$125.00.New billet overdrive carrier.$125.New billet forward drum.$249.00.New CK 3.005" billet aluminum 2nd gear servo.$79.00.Used Art Carr billet servo.49.00.New billet 10 vane pump rotor.69.00.New billet 4340 main shaft for th400.$139.00.TH400 pro tree trans brake.$299.00.New GM Military issue th400 deep pans with factory installed drain plug.79.00.Money order payment only.
Hey Chris --Ill take the Forward drum, Billet overdrive ring gear and carrier. Send me payment info
Chris,
It is under the persons profile and is now called "Start Conversation"
Sent from my iPhone using Turbo Buick
New billet 4340 main shaft for th400 is this the same as the part listed below?
"BRACKET RACER" BILLET INPUT SHAFT/DRUM ASSEMBLY #4CC/BIA
Chris, send me your mailing address and I will send you a MO for the BRF valve body and governor, thanks.
If the billet drum is not sold, I will take that as well.
BRF Valve body sold.Thanks Nick.I have a few 4 of each of the billet parts.
Chris I can't thank you enough Drum arrived today, thanks for helping out a difficult Canadian!
