2004r bq
jimski
In over my head
Need some more help with this trans.After ironing out out the vb problems except the 4th gear shift (which im going to try and fix as soon as the weather breaks)I have a massive leak from the speedometer assembly.It seems that there never was an insert in there from the getgo and fluid comes out like a champ. I need the insert and the gear but im not sure what gear it is.Please help
The 200C, Short tail PowerGlide and 350 have the same trans mount position. The 2004R & 400 have the same mount position also. You would need a different crossmember for the 200C if this is going into a G-body car. Easily found in a scrap yard.
Here's a link for trans specs and a link to determine which speedo gear you may need to correct the speedometer reading.
Automatic Transmission Identification
http://www.montess.org/speedo_gears.html
Speedometer Gear Chart 200-4R
I think there is a little confusion:confused: . Im talking about the The 200c speedo gear and insert wiil it fit in a 2004r bq.I have the 20c sitting around for parts if needed.
