I gotta 2004R from BTO in my 73 Stingray. Ive got a modified govenor and shift kit from Bruce at PT a while back and it helped the tranny by firming up the shift and getting it to hold out to a higher rpm upshift. When I pulled it out of winter storage a week ago and took it for a drive it had a delay and wouldnt upshift from 2nd to 3rd for the first few times. When it does this, I let off the throttle and there is no engine braking as if its in no gear. I push the pedal back down and the rpms jump up quite a bit before it delivers power again. Almost like its slipping. If I put it into neutral and pull it back to drive sometimes it will engage 3rd. When it warms up after driving for a few mins the problem goes away and the trans behaves normal. What could be causing this? The trans is new and has few miles on it and the fluid color and level is good. I dont think it ever overheated. TV cable is adjusted properly and is very taught at full throttle. I do have an inline magnetic filter on the return line from the cooler. If that is clogged could it be causing this problem? Thanks for any response in advance.
John Dirks
Severna Park MD
John Dirks
Severna Park MD
