2004r Fluid Capacity
The Cardinal
The Cardinal is installing a new PTS Xtreme **** kit and PR valve and was wondering if anyboby knows how much hydraulic fluid these trannys require ?
87 GN,stock turbo, stock injectors, 10mm magnecore wires, accufab afpr, RJC power plate, Caspers hot wired Walbro fuel pump, K&N filter, homemade cold air induction, testa chip on its way,shift kit in the batters box.
GO Leafs GO.
The Albertan recommends against using hydraulic fluid in your tranny. ;)
