2004r governor
matt69olds
Ain’t no feeling like Oldsmobling!
anybody have info on gov codes? I have one with a A-2 code on the weights that suposedly came out of a 86 Grand National. Im trying to get rid of the 3900 rpm shift points in my 455 powered 87 Cutlass. Im hoping this gov might help. Thanks!
email me or post here a picture of the governor you are using if you can.if the governor you have is the right 1 there is another issue.if it is not the original you will need to replace governor.either way I can help you.
Post the vb code also
