2004r governor
pulled the vb and found crud all inside the valve body, I cleaned the unit out complete drove the car it was shifting good but wanted what I had in the car which i blew out the lo planet on in another thread.
Might try to clean it again. Doesn't take much to bind up the valves.
What happened to the valve body in the trans you blew up? Might try a swap to that vb/gov combo. Give it a once over cleaning and bolt it on.
The bq trans blew out the rear planet and sprag i think the snap ring came out, that trans works nice so i am going to repair it. I am going to try it's light weight governor in the br7 trans currently being used in the car with the fast 1-2 shift..
Put the bq trans governor inside problem solved. It seems someone switched the br7 governor with a low pro one.
Thanks for all the replys in the thread much appreciated
