2004R trans street/strip or daily driver
brian
Senior Member
Street/Strip 2004R lock up with brake.
This unit has a Monte SS CZ hi-po valvebody (model), and this trans has all the usual parts. Larger boost valves, pump ring kit, Alto clutches (extra throughout) and wide Red band with our shift calibration.(shift kit)
This unit is a lock up with a big servo, and transbrake. The input shaft and drum are hardened. Has a stock pan with a custom baffle for fluid control, and a drain plug installed.
This trans will have nice quick medium shifts, and shift at nearly 5500 at WOT. Perfect for a ported heads and cam car.
Biggest difference between this and the BRF is a later WOT upshift, 5200`ish vs 5500, and a slightly earlier third gear while cruising. (most people never notice) With all correct wiring and switches for a GN, with the correct black plug.
Price on this unit is $1550 + $150 shipping in the U.S. (continental 48) This price includes the core.
This transmission can be run with a 12 inch or fimilar 10in hi-po converter. .
You can also search the trans forum for info on the CZ valvebodies.
This build, when used with the correcct converter is easily capable of running well into the 11`s.
You can view feedback in that forum on this board.
Search under brian, or Brian Hofer
Thank you, Brian
hipsibri@cs.com
