challengermike
- Nov 14, 2005
I need some advise.I rebuilt my 200r4 out of my 86 t type.I am having trouble with a 1-2 shift sliding and the 2-3 shift flare up at more than 1/2 throttle.Any less throttle and it shifts hard.I have tried swapping valvebodys,i blocked the accumlators,i changed the servo,i changed the pressure regulator and i drilled the seperator plate to firm up the shifts.Nothing seems to help.And yes the tv is set correctly.I work at a trans shop and yet i cant seem to get it right.Any advise would be great.Also when i was working on trying to fix this it burned the kevlar band up on wiped the drum and the dierct clutches where starting to burn.I have replaced the band,drum and clutches and i am affraid that its going to burn theses up soon if i dont figure it out soon.I also did a line pressure test and it came out with all the correct pressures acording to an atsg manual.
