204 Camshaft?
the wrath
has anyone used this camshaft and it didnt go flat on them and i want to know how well it work in terms of performance. i am building a new motor and i am on a budget i know a roller cam is better but i want to use a flat tappet cam right now
204/214 is a great camshaft. Wiping a lobe can happen with any cam- the correct breakin is critical to long cam life.
What are your goals? The stock cam will take you into the 11s with the right tune.....
What is your current combo?
www.carparts.com has the Melling MTB-1 for $49.99 .
Same as:
Sealed-Power (Federal-Mogul) CS-1016R
Elgin E-913-P
Clevite (Dana) 229-2020
Melling 21101 (MTB-1)
i have one in my car with over 25,000 miles on it im guessing with no problems, and my dads new motor has one. They are great cams. I had a local friend install one as well and he has not had any problems. Great idle and performance
Dont throw in 20 oil additives with break in. Just the moly coat with the proper breakin procedure, use a good non-starburst oil, drain it, drain again after 500 miles and stick with non starburst oils after that, with half a bottle of valvoline SYN additive with each oil change. The SYN is much better than EOS. Also check the lifter bore clearance on all the lifter bores. If you have just slightly too much clearance, this can accelerate cam wear cause the lifter cocks and drives the leading edge into the lobe.
All that aside, every 10 degrees added duration will push the powerband up about 300-500rpm. Make sure the heads/intake/turbo/valvesprings are optimized for that added rpm or you will just lose power or gain nothing.
They do not currently sell this cam . I have one with new HT-969 lifters. $100.shipped
I use a Reed's 204/204 and like it. I only run 1/8 mile strip's (no 1/4's in my area) and do sreet floggings. Low end and mid-range has excellent response.
i run that cam blew a headgasket and pulled heads looked at the lifters and cam THEY ARE PERFECT ABSOLUTELY NO WEAR broke it in with rotella and eos supplement then run rotella after break in. i ran a 12.98 wiht that cam no race gas and street timing and boost
I got this far?
get a hold of frankg on the board so you dont have to go through the hassle plus it keeps our vendors happy
