Thank you. .
Front body bushings are okay, and I think the middle ones are too on that side, Bilstein shock is out and "appears" to work as far as rebound and compression go, no obvious signs of leaks etc. Not bad anyway for a 14 year old one, if I can get one locally I may change it out anyway.
It's an odd problem for sure and the tires are a bit wider 235/60's but I have been using them for 18 years without any major rubbing issues.
Gotta check the lower control arm bushings as suggested.
I guess it could be a bad spring if the shocks don't do that much for ride height or overall rebound.
End links are fine as well.
I really thought the body was sagging but compared with the GN the WE4 body is at the same level on that side of the car.
I guess I have to really inspect the spring for a break/crack, it's mounted in there properly.
You can move it to suspension if you want to.
