Lil Truck
I spend to much time here....
- Sep 26, 2002
I run the MT 295s SS on my drag truck they improved my 60' the only down side is they are not available in the pro series DR.......yet? They look great on your car!
SignUp Now!Thanks , yeah that's what I'm looking for is to be able to hit the launch with more boost and maybe go through the traps at a little lower rpm . These tall tires are like changing my rear end ratio from 3.42 to 3.23 .I run the MT 295s SS on my drag truck they improved my 60' the only down side is they are not available in the pro series DR.......yet? They look great on your car!
Sam, what are the wheel specs? Am considering them for the LST car...
Dayuum. Nice. So frame notch and narrowed rear? How deep is the notch?
Sent from my VS990 using Tapatalk
Chuck , There is only one size for the front 15x3 , the rear wheels are 15x10 4" backspace . The rearend was 57.75" wide from the face of the drum , the narrowed 3" to 54.75" . I only moved the lower control arm mounts in 1" to avoid interference with my HR bar forward mounting point . The backing plate and LCA mount are almost touching , but I needed that little extra room . This is why I measured and drew diagrams & measured again , and it all came together in the end .
Sam, thanks for the reply.
I have 9.5 x 15's w/ 4.5BS on the car, now. Lip is rolled, and the frame is notched.
I have the LS turbo/4L80E combo, w/ a stock width Quick 9". 275/60/15 TA's aren't going to "survive", for long.
I may start w/ the 295's, and see how that works.
I need to start a tire "escrow fund"! [emoji57]
Global West upper & lower control arms , 2" drop spindles , Hotchkis 1" lowering springs , Wilwood 6 piston calipers with 12' rotors , & Champion Billet 15x3.5 wheels with MT Sportsman S/R 26x6 R 15Looks great. Whats the details on the front suspension?
295/65s are snug.
Deep notch, massaged wheel wells and rolled lips. The height of the 295/65s cause a lot of interference. Wheels are 15x10 5.5 bs.Looks great. What are the specs on your wheels? Rolled fenders? Notch? Thanks
We both ended up the same , your 15x10 5.5" bs & stock width rearend , placed the tire the same as my 15x10 4"bs & rearend narrowed 1.5" each side . It's all about taking accurate measurements .Deep notch, massaged wheel wells and rolled lips. The height of the 295/65s cause a lot of interference. Wheels are 15x10 5.5 bs.
295/65s are snug.
