29x10x15 slicks
ineeda38turbo
right now i have 26x10x15 and they are done, a buddy of mine has some cheap used 29x10x15s and i heard i really wanna go with 28x10s will 29x10s be ok a s far as the track mile per hour times and them fitting in the wheel well?
If you are using a non lock up, then you should wait till your car starts trapping 115mph-
with a lockup, then 117
they wont hurt your performance, i just dont see a car running 109 mph using 29 inch slicks to gain any more MPH-
if you turn the whick up some, i think you should be able to use them if your running 25 psi race gas and race chip-
make sure you got air bags
BW
29X10's will fit if you roll your fender lip. I used several sets. You will need to run an air bag to keep the car up. I rubbed the frame slightly on turns (with a spool). I got tired of hearing the tires run and went to 29X9's. I wouldn't hesitate to use 29's on a mild combo. You gain 60 ft time.....you lose a little gear....itsa wash In my opinion.
Dave
