TireFryer
The New Kid
- Dec 21, 2001
Stock bottom endTire Fryer, what is an SBE?
TIMINATOR
SignUp Now!Stock bottom endTire Fryer, what is an SBE?
TIMINATOR
It also refers to the LS type of engine design.Stock bottom end
I knew I forgot a few things:It also refers to the LS type of engine design.
I just missed someone a month or two ago at the Bell rd/Mixteca Saturday afternoon show. They were just leaving as I was looking for a place to park. You?Where do you live in Phoenix? Where's your shop?
I'm at 7th Street and Glendale. I'm an old white haired guy with a white TR, too.
We should have a beer sometime.
Currently thinking about heat coating the intake, plenum, exhaust manifolds, up and down pipes, and adding 1.65 roller rockers too. Prefer stainless rockers, but will do alum if that's all that's available. T&D hasn't been answering their phone, just about 8 rings and then a busy signal. No answer to my e mail either. I was a dealer, just no purchases lately...I just missed someone a month or two ago at the Bell rd/Mixteca Saturday afternoon show. They were just leaving as I was looking for a place to park. You?
Other than mine, I have only seen a total of two other white ones ever!
Shop is in Avondale near 107th and Indian School. 623-877-8553
M-F 9-6. Sat. 9-1 or 2
Call me!
If you want the best heat coatings , check out Swain Tech .Currently thinking about heat coating the intake, plenum, exhaust manifolds, up and down pipes
Post 45.I knew I forgot a few things:
Cometic HGs with "ears" on the chamber to allow more valve unshrouding
These HGs are designed for 4 bolt heads. They are now known as "the new design 4 bolt head gasket" I will provide the part # later when I go out to my shop.
Fully polished chambers for less heat absorption into the water jacket.
Chamber blended into top valve cut to eliminate flame front dead area around valves.
Chamber reshaping to enhance flame front away from the spark plugs.
As usual, plugs will be indexed.
In my past turbo builds, I have found these Chamber mods allow more low gear timing and faster spooling.
The 62/62 is because I like cooler air, less back pressure, and will not dragrace the car, so I don't need a bigger stall that normally is used with this sized turbo for high boost launches, and immediate boost. A lazier "street" launch makes it easier on driveline parts, and I like my skinny tire cars to be able to "hook in a car wash!" Think "sleeper", and white haired guy in an old white Buick. P.S. I am "debadging" it too. The cops always seem to chase the guy with the fat tires, loud exhaust, decals, and bling, that was spinning his tires, while not noticing that I was ahead of him.......
I live in Phoenix,AZ. where summer temps run in the 115+ during the summer, and I am building this as a "mountain car."
For you "flatlanders", that's a mountain cruiser that may be running sea level plus 8 or 9 lbs boost on the upside of a mountain for 15 to 30 MINUTES AT A TIME!
The front and rear are also lowered 2"+ to enhance handling as are bigger sway bars with urethane bushings.
Turbo size is an experimental collaboration between Jason and myself, and he, and you all will be notified of all of the results!
Weekends will often be spent between 4500 and 9000 ft. altitude, cruising around, messing with the "sports car" boys.
Not much traffic up there, and the non turbo cars are wheezing for air. The latest "Whipple blower" cars are better off, but still the density altitude in Flagstaff (around 6000+actual feet, in the summer runs around 10,000 feet+ on the ground! This car is continuing my forays into the mountain thing.
My last turbo mountain sleeper was a 1979 Pinto with a built Turbo Capri 2300 cammer motor. With 2.79 rear gears, I could put the cruise control on and run 90+ between Second Mesa/ Tuba city area and Flagstaff. That road is a wide two lane with two very sweeping 30 degree curves in around 40 miles!
No cops! It's on the Indian reservation and many top speed shootouts happen there! It's kinda in a big, giant shallow dish and you can see most of the way to the other end! Pinto top speed was in the 135+ area! I did have a roll bar in that one! And a radar gun.....
The mountains are FUN!
More comments, questions?
TIMINATOR
Mr. Spool,The chassis should be setup based on the power that is being put to it and the surface.
Chassis tuning is a separate topic for another thread and there several threads where guys are willing to share has chimed in.
A big block on 91 octane should not be used as a comparison to a buick v6 that should never run 91 octane when boosting anything part stock boost levels.
The hp per hole is not comparable.
800hp on a v8 is 100hp per hole
The v6 has to make 133+hp per hole.
3/4 nozzles and 2 pumps will take care of and base octane lolMr. Spool,
91 is the highest octane "pump" gas you can get in AZ.
Therefore, Alky Control or some type of octane booster is a must.
Or there is race gas at $10 plus a gallon......... Let's go Brandon!
The LS's oiling is very similar and not superior to Buick'sa very good, stock oiling system
Mine is still new in the box, I'll call Dave Monday.Art Carr isn’t the guru of the 2004R. 2500 stall in a car that has that much stall stock? That’s not what he was selling the Buick community for years. It was 3k for a stock cam car. PTC, Dave, or Full Throttle converters are light years ahead of Arts 9”
P.S. anybody have or used one of Arts convertors lately?Mine is still new in the box, I'll call Dave Monday.
And Art.
I need to know how each rates their stall, at what torque level, under boost or not and how much, at the stated stall rpm.
I'm local to Hughes and know many peeps there for YEARS (decades!) I'll talk to them too for info purposes.
As I remember my previous before modded (and first was purchased new) GNs, and my current Turbo Coupe footbrake stalled to 1900/2000 rpm. The first one we did together with my mods in 1987 picked up 350/400 rpm dead stall and a bit more flash stall.
My Hughes GM-25 (2500 nominal stall advertised 11") behind my 454 (iron headed oval port motor) foot brake stalled 3200 rpm and flashed to about 34/3500 rpm. It ran 10.80s all day long on pump gas 3.73 gears, p/s, p/b, a/c street tires and thru the mufflers.
Stall is a torque /boost thing. I question if all mfgrs are using the same standards. I intend to find out!
If anyone wants to jump in with their STOCK, unaltered gn convertered cars stall, please do!
TIMINATOR
That kind of statement is troubling. He did not invent the torque converter, and being able to machine and assemble parts is a whole different skill/capability then being able to understand the operation and apply it to a specific application. Depending on what you want to do will drive the application. On these cars I would not run a 6262 at low boost unless it was running at 8000+ rpm to get 700 HP, and then maybe not then, because I have never seen a 6262 compressor map. These motors in close to stock form are not high rpm motors.He did tell me that if I was smarter than him, build it myself.
