hawkfan
- Aug 24, 2012
I recently had an RJC 3" downpipe and pypes exhaust installed and noticed the dp is resting on the very corner of the frame. The downpipe is 'clocked' to raise the back end of the pipe up but obviously there's not enough adjustment. It clears the heater box just fine. I recently had to replace a broken trans mount, so I'm figuring the motor mounts might need replacing too? The car has 120k miles on it. I did a search here and see a lot of guys use poly mounts, but I don't want additional vibration since this is a 100% street driven car. Would regular rubber replacement mounts raise the engine enough to gain some clearance? I took some pics but they are a little too large. I will try to add them later.
