ILLEGAL REGAL™
- Nov 27, 2004
"skinny frame".. sounds drastic. Mine is notched to the seam or the center then took a BFH to the tubs and made some room.
SignUp Now!I am attempting "operation skinny frame" as we speak. We will see, should work without the spacer hopefully.
these 325's on a 10" rim measure 13.5" sectionI believe if you notch to the weld in the frame that is 2".
I am doing a 1" notch with my current 15x10 4.5" B.S. and expect to have about a 1/2" of tire clearance to the frame. I am basing this off of my current figures of
295's with a 4.5 B.S. are 5.3" towards the frame.
325's with a 4.5 B.S. are 5.9" towards the frame.
Though not every tire is the exact size even if it says 325, with the aluminum drums and poly bushings I am hoping it won't move much while turning to rub if they are wider than the 12.8" section width 325 works out to be. And putting a 325 on a 10" rim will suck in the section width a tad more than the 295 I have on it now.
Banning, is your current 60ft time with your 325's MT's?
we are using a 15X10 with the 5.5 backspace with a spacer to I don't like them sticking out up top
Grumpy, what size spacer? Thanx.
