none of the threads about the F-body bar seem to address my particular problem. I am using the MOOG k6459 bushings with stock G-body brackets, and according to all the threads on here, it should just bolt right up flush. that is not the case. the bushing seems wayyyy to big for the bracket and i cant even get the bar close enough to the frame to get both bolts in the bracket.
Also, the bar is interfering with the jounce bars (which the Elky did not come with, I took them off a Monte Carlo) nobody else has this problem? should I try Energy suspension bushings instead? maybe they have less "meat" on them?
