i have rather large valve heads (GN1R), i was going too build a 109 block that i have but am having second thoughts about the bore size in relation to valve size.
is there anything specific too the 109 block that wont work with the 4.1 block? (other then pistons)
what are estimated or round about limits of the 4.1 block as far as power goes?
what are known problem areas of the 4.1 block?
if there are known common problems, how are they aleviated?
will an RJC girdle work with a 4.1 block?
is it worth going too the larger bore block with my heads over the smaller 109?
TIA
Steve
TIA
Steve
