SignUp Now!Cam bearings are in stock nowshould be on the web site today. Pistons are being made will be about 2 weeks. approx 9 to 1 with 48CC head, 2618 alloy, good pins and rings, pressure ring, bowls mapped to combustion chambers, good stuff.
Mike
 Ran fine on the street then without any issues. I think the HardBlok is necessary to stabilize the 4.1 block. I loved that motor. Wish I hadn't screwed it up. It had goood heads on it when I freshened it up. Oh well, live & learn.
 Ran fine on the street then without any issues. I think the HardBlok is necessary to stabilize the 4.1 block. I loved that motor. Wish I hadn't screwed it up. It had goood heads on it when I freshened it up. Oh well, live & learn.Got me curious mike, what heads, rocker ratio and cam lobe profile and specs??? Turbo choice??
Heads? not sure I was actually hopeing you still had your M&A'sGot me curious mike, what heads, rocker ratio and cam lobe profile and specs??? Turbo choice??
 I will find something keeping with my "budget commonman theme here" As soon as I find something I will post up. As far as the cam goes I am going to use our new XR5 roller which is a 214/214 with a very big .200 duration and lots of lift. This acts like a much bigger cam without the overlap. rocker will depend on the head but roller rocker are needed with this cam. I will set the car for E-85 but will have tunes ups for that pump alky and race gas for the SD2 set up, 120 lb injectors should cover me and turbo wise I am not sure, I did make a deal on a 71GTQ with a customer we will start there but likely end up with something smaller for more "fun factor" on the street.
 I will find something keeping with my "budget commonman theme here" As soon as I find something I will post up. As far as the cam goes I am going to use our new XR5 roller which is a 214/214 with a very big .200 duration and lots of lift. This acts like a much bigger cam without the overlap. rocker will depend on the head but roller rocker are needed with this cam. I will set the car for E-85 but will have tunes ups for that pump alky and race gas for the SD2 set up, 120 lb injectors should cover me and turbo wise I am not sure, I did make a deal on a 71GTQ with a customer we will start there but likely end up with something smaller for more "fun factor" on the street.Oh, if you fill the water jackets as far as I did. You need to drill the steam holes between the cylinders! Guess how I figured that one out?Ran fine on the street then without any issues. I think the HardBlok is necessary to stabilize the 4.1 block. I loved that motor. Wish I hadn't screwed it up. It had goood heads on it when I freshened it up. Oh well, live & learn.
whats the general consensus on the amount of power these blocks can handle? (if kept detonation free of course)
