SignUp Now!Wow. . . 15psi and 4.81 that's mid 7's and want 30psi.... Insane. . . . I want a ride....lol...... wow.... my knees feel week just thinking about it....Thanks guys. I had time to make 1 pass at a local test session yesterday. The logger worked and it went 4.81 at 152 on 15psi. I can't wait to feel this car at 30psi.
Insane.....all that comes to mind. . . .If I get brave enough to run the 1/4 it will go 6's at over 200 with the boost turned up. I'm already having issues with windshield trim flying off at 160. lol. I'm sealing it up to try and keep air from getting under it.
Only change was to address the slower 60'. I guessed that the higher launch rpm was eating up my boost so I added 2# to the launch. It got me a 1.19 4.71 at 158.
Congrats on getting the car going so well. I can't believe how nice it leaves. Can you explain what you mean by what you posted? I think there is something to that and I do not understand it yet.
Congrats Dusty, You car is a work of art for sure.
I remember when you split a grill at 170+If I get brave enough to run the 1/4 it will go 6's at over 200 with the boost turned up. I'm already having issues with windshield trim flying off at 160. lol. I'm sealing it up to try and keep air from getting under it.
Thanks Jason.
Jimmy you can see in Jason's video how quickly something like a Qa1 extends even when set at full tight. It's not a problem for 10 or 11 second cars but anything in the 8's can use a tighter shock. I had to rely heavily on travel limiters to keep from doing a backflip. Using a tighter shock allows you to run more travel which means more weight transfer and that travel is slowed down right at launch to avoid wheel stands.
Qa1 may be able to put a stiffer valving in shocks for these cars. Even some Santhuff and AFCO shocks aren't valved stiff enough out of the box. My Santhuff's have the Pro mod valving. People like Mark Menscer custom valve the AFCO's and they work well. I have his custom valved pieces on the rear.
