Dusty Bradford
- May 24, 2001
Congrats Dusty, heard about the 4.86 pass during the live stream. Pretty damn impressive to run that fast and not even have it sorted out!What I love is when I look at your car compared to all the others it is still the one that looks like a real street car!
Good luck with the upgardes on the car.
Thanks. It does feel good to look at the data and know how much is left.
That pass was only a 1.32 60' due to the new tune-up the 10.5 converter needed over the old 9.5. The 9.5 would 60' 1.27 leaving at 4300 and 4 psi. This 10.5 finally went 1.26 but needed 4500 rpm and 7.5 psi. Once I finally got the car to 60' is when something happened to the power supply to the XFI that I haven't found yet.
From that data alone, the car will run around 4.76-4.78 on that same 23psi. Against Dilliard I had the 1.26 60', 27psi in the controller and had it in .2 sooner. I cranked down on the driver side limiter and the car liked it. The nose was staying down then.........the car shut off
