4" air filter part numbers
9daysbefore
Does anybody know what part number the K&N air filter is that members use that has the 4" opening to use with a Cold air kit from TR Custom parts?
I got one that didn't have the air filter with it (I didn't buy this set up from TR Custom parts - that is why I do not have the filter).
Any other 4" opening air filters that members use?
Thank you,
9daysbefore
Knfilters.com has a product search that allows you to specify filter opening, diameter, shape, length.. the whole nine yards. There are probably a few dozen filters on there with 4" openings.
What is better: A Round Tapered air filter or a Round Straight air filter? This is for the cold air system.
The reason I am asking is because of the following:
K&N filter #RE-0870 is a Round Tapered air filter with a 1 year limitied warranty for $46.99 (this has a 4" flange and is 9" long with a 6" base and 4 5/8" top)
and
K&N filter #RD-1460 is a Round Straight air filter with a lifetime warranty for $48.88 (this has a 4" flange, 9" long and is 7" in diameter)
Thank you,
9daysbefore
Also check these out...
S&B Filters
...basically the same as K&N...except they have a higher CFM rating and are cheaper...
and
Thank you,
9daysbefore
The second one has more filtering area.
