In checking into why my 87 GN is failing CA smog test, I used a Cam Sensor Adjustment tool to confirm my sensor is adjusted properly. This went as expected… Adjustment was OK, but I noticed something while cranking the engine by hand, and need to see if anyone has run into this.
When I turn the crankshaft by hand and then reverse the direction, I read 4 degrees of “Play” before I encounter serious resistance.
I assume this is timing chain “Slack”, aggravated possibly by a worn or missing chain tensioner.
From a SMOG TEST standpoint (I have an ongoing thread in the emissions area) I am blowing high HC's (Just enough to Fail). My ECM is seeing some of this, and pulling fuel out by lowering the BL to the lower limits at 15 and 25 MPH. This was why I was checking the Cam Sensor.
My question here is 4 degrees of play in the timing chain acceptable? I don’t think this is normal, and a see myself replacing the roller chain with a replacement steel + tensioner but wanted more opinions.
Especially any opinions regarding this amount of play affecting the Injector Timing enough to make it run rich!
So, could this 4 degree "Play" be affecting the injector timing enough to cause a rich condition?
Let me know what you think... Anyone else notice this much rotational play when cranking an engine (165K mi) over by hand?
