42.5s Intake manifold, T- body, Plenum, Hardline, Fuel rail , Timing cover, Air box
threerail
NICE 1600 mile oo9 42.5 set of injectors, flowmatched. hardly used, even look real new,.......150
stock throttle body ...with ALL working sensors, throttle brkt, iac and housing, tps, good original condition, not all corroded up just needs some and paint/polish to be real sweet..........100
stock plenum... nice shape, gasket matched to stock gasket, no pitting or corrosion, just paint it,......40
both vacumn hardlines to plenum,... very good useable shape, not corroded, just clean and paint, big one...60....little one.....35. both....90
stock lower intake manifold,...nice used condition,its yellowed over time but in original factory coated condition, not all corroded etc, never been molested or repainted, etc. has all original working sensors in it. egr on it. no damaged threads...........220
2 stock air boxes....complete upper, lower, main stud, elbow, intake duct, mounting base brkt. just need clean and paint. some light rust but are not all pitted or scaled up............40 each
belt tensioner assembly..... with pulley, came off running car, has been welded at corner alternator ear,hasnt recracked works fine. needs clean up and paint to be pretty, ........50 SOLD
coolant hardline....in very good condition, not corroded, .........40
fuel rail...... in very nice original condition, not rusty,......40
stock working injectors to match.... just need new tips and seals to run them.....25
heater bypass valve ......in good working condition..............20
also have factory cat hanger in good solid shape 60 plus shipping,...... factory headers...80 plus shipping....other stuff too, call rob with needs...810 599 8218.. thanks
cat hanger, moog springs, concert sound two stereo, hooker down-pipe tube, head bolts
used factory cat hanger in good condition...........................60
new 5606 moog front springs for gn, in orig box..................60
concert sound 2 stereo, works as it should.good condition.....125
new hooker downpipe cat eliminator tube, 3 inch with4 bolt flange...40
head bolts...
new torque to yield in gm wrappers..................25
used sps bolts, used once, reusable..................25
used arp bolts used once, reusable...................25
add pay pal and shipping from me, my zip is 48327 so check your price from there, you can pm me or call rob with questions 810 599 8218 thanks guys
everything sold except... t body and plenum..air boxes...factory headers...cat hanger...come get em
complete throttle body with working sensors 80.....plenum 30...headers 75....airboxes with ducts complete 30 ...cat hanger 60....SOLD THE REST
