#5 cylinder not firing
I have an 85 GN which has been converted to an 87 ECM and an 87 coil and module. Ran fine for two years then this summer I installed a new engine harness, new injector harness, new valve springs, new rocker arm shafts, new 87 style crank sensor. I also installed a set of used green stripe injectors.
Over the summer I put it all back together and it runs rough, missing on #5 cylinder.
Here is a list of things I have done so far (none of which helped)![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
-changed the spark plug with a new one
-changed the coil and module
-changed the #5 injector to one of the -previous set that worked fine
I also put in a higher stall converter and converted the brakes to vacuum boost but I don't think that should affect anything.
I pulled #5 plug again and it is still wet and black like the first one, I decreased the gap to .025 still no joy.
I pulled the driver's valve cover to insure that the rocker arms were moving and the push rods were moving as they should. Compression on that cylinder is 135 lbs.
I didn't touch the cam sensor BTW.
Any ideas?
Peter Cruickshank
Forgot to mention that I also installed a new fuel filter and a Racetronix hot wire kit for the fuel pump.
Any ideas?
Peter Cruickshank
