50 lb matched injectors + TurboTweak Chip
tbirdv6
Matched 50 lb (6) MSD injectors by Precision Turbo-less than 1500 miles
Eric Marshall (TurboTweak) Programable Chip to match above injectors
Chip Features:
Version 5.5 for 86/87 Buick and 89 TTA
-User Adjustable features! - requires a scantool,
-User adjustable wide open throttle fuel, +/- 20%, also adjust 1st gear WOT fuel independently +/- 20%
-User adustable wide open throttle timing, +/-9 degrees, 2 separate settings - 1st/2nd gear and 3rd/4th gear.
-Open loop idle for smoothness, idle BLM still has learning capability (not locked to 128).
-For alcohol injection, special timing curves to help reduce "transitional" knock.
-Variable timing based on mph and airflow, provides extra timing in the low/mid boost area.
-BLM lock at WOT to improve consistency.
-False knock ignore capability for launch, turns off when preset mph is reached if requested.
-Antistall, helps prevent stalling and reversion through the MAF when lifting off throttle after boost, helpful with higher stall converters.
-MAF/LV8 locks on to 255 under wide open throttle conditions for consistency.
-MAF "Dropout" ignore
-No EGR, egr function is disabled
$275 shipped
Paypal accepted,add 3%
FRED
turbobuick4@yahoo.com
I'm interested... Curious, what scantool is needed to adjust the chip. I've got direct scan right now.
Do you have all the instructions with the chip (as I have no clue how to adjust one)... should probably just leave it alone:biggrin:
Do they need new O rings?
Can I get a pic of the injectors to see overall condition?
Thanks.
Thanks.
I have the orginal instructions
Direct scan works great to see the adjustments
less than 1500 miles & no "O" rings needed due to the new condition they;re in
FRED
Payment received!
Injectors & TT chip w/instructions packed & ready to ship!
Will send out on Monday via UPS,meaning you"ll receive by Tuesday since we're neighbors
Thanks Jeff
FRED
