slimtastic
yea dude...I rock
- Aug 9, 2002
ok so im starting to get a rough idea of what my next motor build will be and a couple major questions are sitting in the way that i need pointers on. my build is based around a tall deck bbc and the planned displacment is 520 cuin, so ill lay out the basics of my build to this point
max rpm redline 6500-7000
4.375 stroke
4.35 bore
6.700 rod length
planned compression 8.5-8.8 with custom pistons
build around pump gas 93oct for 90% of operation
planned for 900-1000 WHP on 93
planned boost under 15 lbs oct
88-91 mm single turbo
planned heads- tfs-41400008
360 cc intake
122cc chamber
solid roller .700 lift
planned cam specs... im thinking a custom cam for the odd cubic inches
intake lift .702 at valve
exhaust lift .702 at valve
intake duration (seat to seat) 295.
exhaust duration (seat to seat 305
LCA 115
intake center line 115
my main questions are about the cam. this is a rough idea of what i think would work good with the combination ive laid out at this point but id love some of you in the "know" to critique the cam ive spec'd.
also what kind of roller rockers? am i really gonna need 1200$ shaft mount rockers like i see everyone getting or would a good set of stainless bodied comp roller rockers do the job for .700 lift?
also any other questions and comments about the combination at hand are more than welcome. i just need to see if im headed in the right direction for my power goals
4.375 stroke
4.35 bore
6.700 rod length
360 cc intake
122cc chamber
LCA 115
