SignUp Now!Is that the new style air cool dual bb?
need a blow off valve. withut it it is harder on these new billit turbos
Been running a 6262 water cooled turbo for about 4 years now, knock on wood, no issues.
Been running a 6262dbb for over 3 years on the street with many hard miles. No blow off valve and no issues. Only issue I have is keeping a set of rear tires on the car!My 6262 went bad quickly. Has anyone else had problems with their Turbo?
Clark6 said:You say went bad.. Exactly what symptoms did you come across to say it's bad?
Unlike me at first, make sure you let the oil pressure get down to a warm operating temperature, too much oil psi is bad at first. Too much psi got my 6776 bb, (loved that turbo). At least I think that's what got it by getting on it early without letting the car warm up good, too many times and finally let go.
Here are some more tips.
http://www.turbobuick.com/forums/threads/save-your-turbos.369290/
my 6262 is air cooledIs your Turbo water or air cooled?
The seal can't really let go as a result of itself unless it was faulty to begin with. It's an iron sealing ring like a piston ring. There are a lot of possibilities as to why oil could get past it though.Clark6 said:That's possible too Bison as I was stumped as to I've gotten on it plenty of times over the few years I had that turbo with no problems until then. Guess I was grabbing at straws & couldn't find any other reason. lol.
Mine wasn't a bearing my seal let go on the exhaust side; shaft play and bearings were fine.
Shaft play
