IhaveAcarSickness
- Apr 12, 2012
stock headers..with a little bit of clean up done
SignUp Now!stock headers..with a little bit of clean up done![]()
Are you still going to use the 2 o ring adapter to mount it to the intake? see ya! Johnexplain why you think that? and heres my response,well i serched everywere for headers,here is what i found,poston h/a headers witch are just about 1/8 bigger then stock for 500custum headers for 2to3000
or the i got a new shiny set of speed daddy hot rod headers with more work to make fit with no proof of any gains...YET, or the stockers that will go into the 10s forsure,and since my car probably wont see 10s,IMO that turbo will be fine 2 1/2 upipe and 3inch dp gets it in fast and out faster o ya all that head work helps too
The reason I asked about the 2 oring adapter was on my 62 turbo we had the lower end cut off and welded to the bottom of the compressor end of the turbo to cut out the restriction of the small end of the adapter. See ya! Johnyes im still using the 2 oring connecter ported along with all the work i put in my intake.now first off there boost your CONSTRUCTIVE advice was that is a waste of a turbowas that helpfull in helping me?so i asked you to explain why,for help and you basiclly went into little man syndrome on me and took your little red ball and went home . i dont know it all nor said i did but if i hurt your feelings by buying my wasted turbo and saying my ol h/a aint gonna run 10s anyway,just stay off my thread,thanks George
How long will the stockers last before they will have to be fixed over and over until you can't weld them no more.
Sent from my SPH-M820-BST using TurboBuick Mobile mobile app
When are you going to the track? I can't wait to see what it will run and what your air temp numbers are I can't get mine below 200 degrees with the hot air intake See ya! JohnO it runs great and ya can't wait to get them numbers I'm looking for...
