slo-joe55
- Jan 12, 2007
Bent6,
Thanks for that info.
SignUp Now!I say that all the time to a few guys I know when they cringe at turning the boost up over 25psi
Don't matter if it's a bone stock motor, Aluminum headed stroker or a 615 Big Cheif....the fun begins when the gauge pegs 30:biggrin:
Get a life if you have one. You are all show but no show.
couldn't resiststock shortblock with champion ironsThere's a car in South Florida that has been 9.59 @141mph with a 67 P-trim turbo on an iron headed 231ci 109.
Made it to the track 2 months ago in October... as you already know different car from back then.... My turbo in this build is a 6766 w/ .85you make it to the track yet?
. What was your boost at when you did 105 in the 8th?Made it to the track 2 months ago in October... as you already know different car from back then.... My turbo in this build is a 6766 w/ .85
car went 7.0 @ 105 mph ... Off the footbrake and blew the tires the whole 60ft. XFI issues with crank sensor ended our 1 pass day... Got XFI back a couple weeks ago and Otto finished tuning last week. Going back to track in the spring keep you posted
Boost was 25lbs..... It was the initial pass w/new turbo , XFI , TR6 ignition and other parts . So we didn't know what the boost was gonna hit on 1st passWhat
. It should now run like a raped ape with the right air / fuel #s... It's gonna feel like a different car!! Post up new #s when you get them.Now that Otto retuned the car... Its running much smoother and the numbers hitting right on target in high gear
Cant wait to get back to the track in the spring
